Will not fire
Discussion in 'Dodge Truck Forum' started by Slimntall, Sep 9, 2017.
  1. Slimntall
    Slimntall Member
    Dec 13, 2015
    19
    Work p/t at local hardware store
    Arizona
    Help! My 2002 dakota 4.7 quit running while I was driving it. The instruments died at the same time. Used a code reader and found no codes. Have looked for loose connections, and bad fuses with no luck. Anybody got a clue where I should look next or what is most likely to be the problem. Oh, it cranks over fine, just won't fire.
    Thanks for any help!
    12,759
    7,911
    need to determine lack of fuel or lack of spark
    gmctrucks and chevychase like this.
  3. Slimntall
    Slimntall Member
    Dec 13, 2015
    19
    Arizona
    Plenty fuel, no fire.
    chevychase likes this.
  4. kbrown11
    kbrown11 Full Member
    Dec 5, 2015
    1,232
    2,158
    Alburquerque
    Try switching the Auto Shut Down relay with another similar relay in the fuse box.
  5. kbrown11
    Dec 5, 2015
    1,232
    2,158
    Alburquerque
    Did you put a fuel pressure tester on it? Can you hear the fuel pump pressurize the system?
  6. leolkfrm
    12,759
    7,911
    how did you determine fuel?..did you prime it or looking at gauge ?
  7. Slimntall
    Slimntall Member
    Dec 13, 2015
    19
    Arizona
    Had over 1/2 tank before it shut down. What puzzles me is what componet affects both spark and gauges?
  8. Slimntall
    Slimntall Member
    Dec 13, 2015
    19
    Arizona
    Where is the auto shut down located, can't find it called out on the lid of the box under the hood or the fuse block on the dash.
  9. leolkfrm
    12,759
    7,911
    prime it with silicone spray thru air intake while being cranked and see if there is a response....just because its in the tank does not mean its getting to the engine, can check for fuel pressure on rail too
    gmctrucks, chevychase and kbrown11 like this.
  10. dirtrider73068
    6,914
    4,427
    Yup just because you have half a tank don't mean maybe the fuel pump quit, would check all fuses related to the engine make sure they are not blown. If don't have gauges at same time it quit sounds electrical something in the ingnition maybe.
