Washers stop washin
Discussion in 'GMC Truck Forum' started by gmctrucks, Sep 7, 2017.
  1. 96silverado
    96silverado Full Member
    Sep 23, 2012
    2,634
    3,708
    These look like they are kinda cold soldered, maybe re-solder these two.
  2. gmctrucks
    8,750
    4,409
    They fooled me as well but it's just two plastic tabs holding the board
    96silverado likes this.
  3. kbrown11
    kbrown11 Full Member
    Dec 5, 2015
    1,162
    2,016
    Alburquerque
    Is there power to your pump?
  4. gmctrucks
    8,750
    4,409
    #14 gmctrucks, Oct 10, 2017
    Ok guys I have been dealing with the same thing no washer pump action so I bought the pump mine was rusted up bad and I said I’m not even going to ohm it out because it’s in bad condition so I bought a new pump put it on without primIng it and it’s a no go so I finally checked for power again and I did have a bad ground when I checked it the first time with my test light so I used the brake line and I do have power going to my pump BUT what I noticed is the new pump has no ground for it to plug into with the factory plug like the original one did so maybe I just bought a defective pump I’m going to return it instead of grounding it out.
    Have any of you guys seen this before?
    Ok guys I confirmed with O’ Reileys auto parts that the pump came defective it’s missing the ground prong.
