Turn signal problem and interiot lights.
Discussion in 'Chevy Truck Forum' started by mickey223, Oct 14, 2010.
  1. mickey223
    mickey223 New Member
    Oct 14, 2010
    I have searched and searched, and can not figure this out.
    When I turn right, the rear bulbs blink, but the front turn off and the interior flasher indicator blinks very fast. Same for when the hazard lights are on.
    I've replaced the bulbs, checked the fuses and all work.
    Not sure if this is related, but also my interior lights won't come on unless the light switches are pressed. I've checked the dome overide switch, entry and exit settings on the information dash. Another odd thing is that even when I turn the panel dimmer all the way to the right they still don't come on. But if I push the switches on the lights they come on.
  2. cburcham73
    cburcham73 Senior Member
    Aug 22, 2008
    305
    electrician
    williamsburg virginia
    sounds like you light switch is shot.. check all your grounds to.
    I guess it is a chevy? Clean all the contacts where your bulbs go especially rear ones.
    Door switch may be bad. Mine does that can push it quick a few times work then won,t.
