troubleshooting problem
Discussion in 'Chevy Truck Forum' started by old red truck, Dec 10, 2017.
  1. old red truck
    old red truck New Member
    Dec 10, 2017
    Hello. I have a 1988 Chevy K2500, 5.7 Liter. The following problem came up suddenly. It Starts fine in the morning, drives fine, but if I shut it off for more than 15 min. and go to restart it, It runs terrible. Like it has no power and is running very lean. Check engine light comes on and the trouble code I get is a 44. Sometines it will clear up and run fine as I drive and sometimes it will continue to run bad. I replaced the O2 sensor and it did not help. The fuel pump is a after market item about 4 years old. Where do I start?
  2. JTWard
    JTWard Full Member
    Sep 3, 2012
    1,257
    946
    I'm retired.
    HI and Welcome. Right behind the thermostat is a 2 wire sensor, ( It's the temperature sensor the PCM uses to adjust the throttle bodies and signals the fuel injectors to work.) And it only cost $22.00
  3. old red truck
    Dec 10, 2017
    Does the following sound correct for testing the temp. sensor on the truck. Check for 5 volts going to the sensor with key on. Also 1.5 to 2 ohms between the pins of the sensor with the engine cold . With a warm engine the ohm reading should drop.
  4. gmctrucks
    9,057
    4,796
    Now that your in that area check the two ground wires that are attached to one of the stats bolts mine broke and I didn’t even know it good luck! GMC
    MikeG and JTWard like this.
  5. JTWard
    JTWard Full Member
    Sep 3, 2012
    1,257
    946
    I'm retired.
    Yes, but the 2 wire sensor in transmit signal to the PCM, Not really sure of the 1.5 volts but it sounds like it. Also on the drivers side of the engine has a sensor right above the #1 spark plug. It's for the temperature gauge and has a single wire going to it.
  6. mowfixer
    mowfixer Full Member
    Jun 20, 2011
    765
    1,462
    Sanford, NC
    Click HERE and it might
  7. old red truck
    Dec 10, 2017
    Turned out to be a faulty fuel injector. It would seem to stop working sometimes once the truck warmed up.Replaced the fuel injector and seems ok now.
