Transmission problems - 4L60E
Discussion in 'Chevy Truck Forum' started by Plyc1500, Aug 2, 2013.
  1. Plyc1500
    Plyc1500 Full Member
    Sep 26, 2010
    17
    Hey Chevy -
    I'm having an issue with my '97 C1500 (4.3L, 4L60E trans). It's now got 394,000 miles on it and I was really hoping to get 400K but it doesn't look like I will so any help would be appreciated. The body and under carriage are shot but she always ran great (all day at 90MPH without complaints).
    Anyway, the other day, I was coming home from work and the truck just started coasting... like it popped out of gear and when I gave it more throttle, the engine just revved like it was in neutral (though the indicator always read Drive). Coasted off the road (for once a rest area when I needed it was right there) and stopped.
    Ran the shift lever through the positions and it felt sloppy and the gear shift indicator sometimes wouldn't even point to the correct gear. Through a series of maneuvers, I was able to make it home.
    I had replaced the Neutral Safety Switch last year due to backup light issues so I figured that was it again. Got a new one at AAP, put it in and same thing. It doesn't seem to know what gear it's in. Sometimes, it only has reverse and a few minutes later, it won't have reverse but only moves forward.
    Is it as bad as I think it is?
    Truck is not worth putting money into but I don't mind putting time into it so I can get it to 400K.
    Sounds like the switch or the fuse has blown? Check fuse 16 i think in fuse panel. Also do this check fluid when cold notice where it is on dip stick.
    Then start the truck..get warmed up check fluid to see if it has any movement/drop on dip stick. But sounds like switch..no right shift indicator??
    Did you install right? Sure acts like pcm does not know what gear it is in..check grounds..pcm grounds all to shift.
    Weird it done it going down the highway? PCM/ECM GROUNDS THESE FOR SHIFTS..OR TELLS WHAT GEAR YOUR IN.
    Can you manually shift any..look this over see what best fits your symptoms 30 Common 4L60E Transmission Problems & Repair | Charlotte NC Need to find a wiring diagram ..could also be ignition switch maybe?
    If converter went..would do this..but the indicator..has to be electrical?
    Wore out tonight worked much today no not drinking lol ...most of that from thinking tired..all over the place but need to check all also check for codes. here is the diagrams.
    [​IMG][​IMG]
  4. Plyc1500
    Sep 26, 2010
    17
    Error code is P0102 MAF or VAF low input.
    Couldn't imagine that would cause all these transmission problems however?
  5. dirtrider73068
    6,924
    4,440
    Do you have any drive or reverse at all? If not it may be the pump is shot.
  6. Plyc1500
    Sep 26, 2010
    17
    There seems to be always something... but often it like it starts off in 3rd or 4th gear.
    Once I get to a certain speed (in 3rd/4th from a dead stop) it downshifts to 2nd (probably via TV cable), picks up speed and then could be okay or just jump into neutral (nothing)... gearshift indicator stays where it was.
    Reverse is spotty... sometimes there & sometimes not.
    Check fuses first thing...check for 12 volts on the maf pink wire. Should be 12 volts..might be your problem .. a ignition fuse blown.
    Here is the diagnostics on the maf.ww2.justanswer.com/uploads/Bluegorilla/2009-10-13_135224_1997_w_p0102.pdf
    Link not work..seems your truck is in limpmode..will only get 2nd and reverse. Check all fuses.
    There is no tv cable on yours see if this link works Then, like a reference guide check this TSB DTC P0102 MAF
  9. Plyc1500
    Sep 26, 2010
    17
    Okay.. thanks. Checked all fuses. Everything OK (even ohmed them out to make sure they were good).
    I'll check the voltage tomorrow per diagram.
  10. bjackson
    bjackson New Member
    Apr 4, 2014
