Tires for RC 3.5 inch lift
Discussion in '4x4 trucks / off road' started by Tristan Eakin, Nov 30, 2016.
  1. Tristan Eakin
    Tristan Eakin New Member
    Nov 30, 2016
    I have a 2011 GMC Sierra SLE z71 with a RC 3.5 inch lift with the upgraded control arms.
    I tried out some 305/55/20 yesterday with stock 20" wheels. They rubbed just the sway bar and no plastic.
    I was looking into 295/55/20 but I don't know if that will still hit the sway bar. I don't care if it rubs plastic because I'll just cut the fender so that's no problem.
    I wanted to see y'all's preferences on what I should get.
  2. MikeG
    2,914
    2,162
    Richland, Wa
    You need to find out what the back spacing is on your rims and what is recommended for the truck now that it has been lifted. Then from there you'll know if #1 you can even use those rims and #2 what rim and tire set up you will need.
