Tired of the code 32
Discussion in 'Chevy Truck Forum' started by ETRNL, Dec 16, 2010.
  1. ETRNL
    ETRNL Senior Member
    May 6, 2010
    106
    Prairieville, LA
    I have replaced all the vacuum lines, the egr valve and the electronic controller. I am still get a service engine soon light almost every trip. Any tips on how to fix it or delete the problem would be greatly appreciated
    Just going to ask did you clear codes. Probably did . Just take battery loose for 30 seconds or so then see if it comes back.
  3. ETRNL
    ETRNL Senior Member
    May 6, 2010
    106
    Prairieville, LA
    I did clear my codes once a week but I stopped after a while because I hate programing radio stations. But I did recently clear it when I changed my plugs/wires. But yea It throws a code daily
  4. Ihatemyford
    Ihatemyford Senior Member
    Dec 8, 2009
    195
    cook
    my truck did the same thing forever and after i replaced the MAP sensor, even more problems started up... hopefully you dont have the same problems that i have.
    Could check vacuum line to map sensor, Also did you clean passage way at egr or see if it was stopped up.
  6. ETRNL
    ETRNL Senior Member
    May 6, 2010
    106
    Prairieville, LA
    My heads are under a year old so no blockage. I changed all of the vacuum lines and I believe my map sensor was replaced in may
    From my experience with the code 32 , you have checked and replaced . They will go off with so many cranks of engine.
    I have a vehicle the code came up found a vacuum line broke , replaced it could not get cel off.
    Went off on it,s on.
  8. ETRNL
    ETRNL Senior Member
    May 6, 2010
    106
    Prairieville, LA
    Hmm. Ok let's start from square one with a new egr valve. If y'all have time I will work this over again starting with what ever y'all say. Where to begin?
  9. leolkfrm
    7,916
    Have you checked the timing?
  10. chevychase
    #10 chevychase, Dec 17, 2010
    Ok you changed egr, , and controller and vacuum lines . When you hooked vacuum line to controller, did you put it on bottom nipple.
    Should have two put it on the bottom one. Code 32 means high vacuum in circuit. Like in a leak some where.
    Also make sure your getting good connection at controller, no oxidation ect.
