The Reference Thread
Discussion in 'General Truck Forum' started by bradrhale, Oct 31, 2009.
  1. Bad88
    Bad88 Full Member
    Dec 8, 2014
    2,085
    4,045
    New York
  2. Bad88
    Bad88 Full Member
    Dec 8, 2014
    2,085
    4,045
    New York
  3. hatzie
    hatzie Full Member
    Mar 17, 2014
    397
    730
    Northern New England
    Spreadsheet to make RPM tables
    I made a spreadsheet many years ago that automagically calculated a lot of basic information based on tire size, axle ratio, transfer case low range ratio, and transmission ratios. You can do a lot of what-if stuff with this and print the results if you want...
    I also added the capability to add the ratios of your external low range boxes (like the Ranger II or the NP203 that was popular for double low range for a while) and Overdrive boxes.
    It will churn out several tables;
    1. RPMs at multiple road speeds in high and low range that include half gears for splitters (extra low range or overdrive boxes). A 1:1 splitter ratio will turn these half gear lines off in the RPM tables...
    2. Ideal speedometer gears.
    3. Speedometer gear ratio adapter calculations.
    I used basic IF THEN ELSE logic and mathematical formulas. There are no VB Scripts or Macros.
    This .ZIP archive contains two spreadsheets. One Microsoft Office Excel 1997/2003 .xls file and one Libre-Office Calc .ods file. The Libre Office suite that will open the .ods file is free for Windoze, Linux, and Android tablets.
    Before you make changes save a backup copy.
    Zip archive link on Mediafire followed by a screen grab of the first page of my spreadsheet open in Libre Office Calc.
    RPM_Gear_Axle_Transmission_TransferCase
  4. BurbanMan
    BurbanMan Full Member
    Jul 22, 2014
    1,230
    990
    Stove tech @ true value
    Cortez, CO
    Holley carburetor parts reference
    MrMarty51 likes this.
