The Reference Thread
Discussion in 'General Truck Forum' started by bradrhale, Oct 31, 2009.
  1. MrMarty51
    I seen and, checked out this thread when I was looking for differences between the married and independent Transfer Cases for My 59 Power Wagon. Wanting to use gears/bearings/caps from a GM T-Case into the isolated T-Case of the old truck.
    Maybe, one of the mods. could add the information that C.C. posted in My thread. Might be helpful to someone, someday.
    MrMarty51 [​IMG] Senior Member [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] Join DateAug 2013Posts2,020
    Swapping input gears bearings ect in NP205s
    Dodge, Ford and GM input gears are all internally interchangeable in all NP205s with one MAJOR detail:
    GM 27 and 10sp, and Dodge 23 spl all used a SMALL dia input bearing and seal. These shafts can be swapped directly among themselves.
    GM32, Ford 31 and Dodge 29 spl used a LARGER dia bearing. These shafts can be swapped among them selves directly
    Wiper washer fix 88 thru 98 video
  4. MrMarty51
    OH SHUCKSSSSsssss, I done gone spent the money and bought a new board for the 93. :no: About a year or two ago. :rofl:
    Just in time though, the 91 is needing that done now. :applaud: :woot: :rofl:
  5. BurbanMan
    BurbanMan Full Member
    Jul 22, 2014
    1,230
    990
    Stove tech @ true value
    Cortez, CO
    For the sake of knowledge
    Timing advance" refers to the number of degrees*before top dead center(BTDC) that the spark will ignite the air-fuel mixture in the combustion chamber during the compression stroke. Retarded timing can be*defined*as changing the timing so that fuel ignition happens later than the manufacturer's specified time. (ATDC)"
    That means the spark happens before the*piston in*the*cylinder is at TDC. Too much*before TDC and the spark will ignite the mixture and try to push the piston*back in the other direction and fight crank shaft rotation during compression stroke. This makes for hard/slow cranking and pre detonation,*ping or spark knock on a hot engine. It increases cylinder temps on a loaded engine and fires off the mix before full cylinder compression.*Super hard loads*on rotating assembly and will trash bearings, rods, crank*and pistons especially. *
    *Altitude changes that max timing threshold quite a bit.*Less air or density*means less air to compress. This lowers compression and changes the point of detonation.*10°*above stock base timing on a tuned,*carb V8 @ 8,000*alt. and it will never ping unless your running totally **** fuel or have a massive vacuum leak.
  6. BurbanMan
    Jul 22, 2014
    1,230
    990
    Cortez, CO
  7. BurbanMan
    Jul 22, 2014
    1,230
    990
    Cortez, CO
    YOU.............
  9. BurbanMan
    Jul 22, 2014
    1,230
    990
    Cortez, CO
  10. BurbanMan
    Jul 22, 2014
    1,230
    990
    Cortez, CO
