The adventure begins
Discussion in 'Chevy Truck Forum' started by smokybandit, Oct 13, 2017.
  1. smokybandit
    smokybandit Full Member
    Jan 26, 2012
    606
    755
    paid fisherman
    texas
    Got the parts a lot cheaper from Allstate Gear Inc. They told me the carry NV4500's on hand for $900/ea. Still i am only in to the "transmission" part for $500ish. Already called Drive Shafts Unlimited and they quoted me around $175 to modify my drive shaft so is can compensate for the length difference between the auto and manual trans. Already fired the truck up, Shifts fine but hoping i just have to bleed the slave cylinder and not replace it. Clutch pedal seemed soft to me.
    MikeG and kbrown11 like this.
  2. smokybandit
    Jan 26, 2012
    606
    755
    paid fisherman
    texas
    UPDATE: Got back from Driver Shaft Unlimited in San Antonio . They first quoted me $180 to just extend it and said that it might be ready by Monday when i dropped it off Thursday morning. They called me Friday around noon saying it was finished.Driver shaft extended, balanced and new carrier bearing for $150. Just extending the forward shaft and balancing it was only $71.64.
    Part stores wanting 180-200 for the carrier bearing, That place only charged me $67 for it.
    kbrown11 and MikeG like this.
  3. smokybandit
    Jan 26, 2012
    606
    755
    paid fisherman
    texas
    Got the truck off the trailer today. Did a short test drive every thing seems fine. Next need to make the support bracket for the clutch assembly. A slight tap from the transmission that goes away when in gear. But hope that goes away once i recheck the fluid levels.
  4. smokybandit
    Jan 26, 2012
    606
    755
    paid fisherman
    texas
    #34 smokybandit, Dec 21, 2017
    Clutch support bracket made and installed, Reverse wired in, Already logged 10 miles. Factory ECM/ computer.
    Goal is to get 1-2k miles on the transmission before i put it to work.
    Now for the numbers, This is what it cost me to do most of it myself. A lot of money was saved have the many parts from donor truck. IE, transmission support bracket, NV4500 transmission
    Clutch kit(clutch, pressure plate, thro out bearing, pilot bearing) $185
    Master GM NV4500 rebuild kit $280
    Parts bought from local transmission shop New Shift Tower $086
    GM input shaft $060
    5th gear syncro $050
    Misc Bolts $010
    Drive Shaft modification $77
    New Carrier bearing $65
    Smashed fingers, number of times cussed, etc $000
    Rough Total------------------------------------------------------------------------------$813
  5. smokybandit
    Jan 26, 2012
    606
    755
    paid fisherman
    texas
    #35 smokybandit, Dec 22, 2017
    Did a 30 mile test drive. Bad part seems that the Fork for fifth gear jumped off shifter fork and now is stuck in 5th even when shifter is in neutral. reverse still works. Will try to see why 5th fork jumped.
    After looking i have a lead on why it might be stuck in 5th. After messing with the shifter and listening to the synros engage. I noticed the syncro sound was missing when the transmission as shifted in to and out from 5th. After reviewing my my memories of rebuilding it i never recalled making sure the carter pin win in the shifter for for fifth gear. Hopefully i can check to verify that if there is one in it or not. The reason it could have shifted trouble free on the bench is that there was no load on the shift fork when shifting from 4th to 5th.
  6. smokybandit
    Jan 26, 2012
    606
    755
    paid fisherman
    texas
    Once it gets warmer i'll install the missing roll pin.
    kbrown11 likes this.
  7. smokybandit
    Jan 26, 2012
    606
    755
    paid fisherman
    texas
    UPDATE:
    Think i found why it was stuck in fifth during the test drive. After searching i found out i installed the roll pins incorrectly.
    New pins correctly installed, now waiting for 1hr cure before i tighten down the bolts. Then i have to wait 24hrs before i can fill it back up.
  8. smokybandit
    Jan 26, 2012
    606
    755
    paid fisherman
    texas
    First 250 miles trouble free
    mowfixer, MikeG and kbrown11 like this.
