That Darned Heater Hose!
Discussion in 'Nissan Truck Forum' started by Avian, Dec 8, 2015.
  1. Avian
    Avian Full Member
    Dec 8, 2015
    What is the easiest way to replace the heater hose on a 2000 Frontier with a 2.4L engine that connects to the back of the engine? Tat connection looks mighty daunting to get to!
  2. jkeaton
    3,125
    5,213
    There probably is no easy way short of pulling the engine out. Just take your time and hope you have flexible arms.
    3 people like this.
    Might need a special disconnect tool..when searching search ford also find better results..click here for nissan frontier forum.
  4. Avian
    Avian Full Member
    Dec 8, 2015
    Well.... after a good meal, I put on my thinking cap and revisited the vehicle. I jacked it up and removed the right front wheel/tire assembly. The inner splash guard flap was long gone. I shone a bright flashlight and saw clearly the hose connection just above the starter in the engine block. I was able to remove the factory clamp using a very long 1/4" extension with 8mm socket. A pry type large screwdriver got the hose off the fitting. There were many hoses, lines, pipes, cables that prevented me from getting my hand on the hose from that vantage point... so I got a stool and was able to pull the hose (previously disconnected from the heater core) out. Putting in the new hose required a bit of double jointed finger and wrist action, but, I used a dab of liquid hand soap to enhance my success to getting it on.... and that seemed to work. Then, I had to use that long extension in conjunction with the long prying screwdriver to get the clamp into it's position and to tighten it. Overall, it was a tough job, but the satisfaction of getting it done was great! Thanks to all for their inputs!
  5. dirtrider73068
    6,923
    4,440
    Most times if replacing hose cut length wise down the hose then open up the cut line hose comes right no prying. Most coolant hoses overtime and heat glue onto fittings.
    3 people like this.
    Glad you are a Gitter Done guy..thanks for posting back your dilemma and fix
    Avian
  7. MrMarty51
    HA, YES, Another story of success.
    Several heat and cooling cycles then, remove tire/wheel, get out extension and socket and, giver another snugging, do not want no hoses jumping off from connectors whilst buzzing down the freeway. :no: :help: :rofl:
  8. leolkfrm
    7,919
    had that happen on a 2.5 in an 86 celebrity
  9. MrMarty51
    I use a slight amount of dielectric grease on the hose, makes them slide onto the fittings a lot better but, a feller better be right onit, hose could slide off if not re-tightened.
  10. Avian
    Avian Full Member
    Dec 8, 2015
    I'd have never considered using dielectric grease that way. I used a dab of dishwashing liquid. It acts as an excellect lubricant and it becomes inert as a lubricant after it gets hot and/or hot, alcohol based coolant hits it. Been doing it that way for years, and haven't had one come off yet.
