spark plug question
Discussion in 'Chevy Truck Forum' started by budynabuick, Nov 2, 2009.
  1. budynabuick
    budynabuick New Member
    Nov 2, 2009
    Hello my name is keith and this site is GREAT so hello to all. My father in law has a 94 silverado with a 5.7. He gave me plugs to put in it and i assumed they were the correct ones but after putting them in I discovered he had given me plugs for a 94 5.0. I have not driven the truck since replacing with the wrong ones but i did start it and it ran great at idle and while throttling it. my question is would it be alright to drive the truck with these 5.0 plugs in the truck? Will it make that much of a difference using these plugs that are for the 5.0 as opposed to the ones for the 5.7? My father in law (now 78) has always been a mopar man but he fell in love with this chevy. everyone was stunned that he wanted the chevy as opposed to the dodges he has driven all his life. BTW, the plugs look identical other than the numbers. we wil be having many more questions as we progress in my father in laws new found love for the venerable chevy P.S. I myself have always been a chevy man. Thank you for any help.
    Keith
    7,919
    check and see if they are the same, if not change them, a wrong heat range could damage the engine, too long of an electrode could damage the piston
  3. BernieB
    BernieB Full Member
    Jul 11, 2009
    3,880
    37
    Both engines use the same plug (RV15YC4 if I remember correctly) so you're good to go.
  4. jremington59
    jremington59 Senior Member
    Oct 21, 2009
    85
    I was going to say the same thing as Bernie. They use the same plug.
  5. budynabuick
    Nov 2, 2009
    Thanks very much. I showed my father in law this web site and he now wants to get a computer to get in all the fun. another question? he also purchased a thermostat for the 5.0 would that fit the 5.7 as well? It is a 180. I'm sure we will have many more questions in the future. Thanks again
    Keith
  6. bradrhale
    it should fit but i dont think that a 180 was a stock thermostat for that truck. i was thinking it was a 190 or 195. contrary to what makes sense, cooler is not always better. that engine was designed to run at a certain temperature and it does not make it to that in an adequate amount of time, hence the later opening higher temp thermostat, than it will not run at its full potential. for a good burn, you want the block hot and the fuel cold along with entering air.
  7. BernieB
    BernieB Full Member
    Jul 11, 2009
    3,880
    37
    Yup, same thermostat also. However, the book calls for a 195, not a 180.
  8. bradrhale
    beat ya to it bernie.
  9. BernieB
    BernieB Full Member
    Jul 11, 2009
    3,880
    37
    Yeah, but I knew it was a 195 and didn't have to guess. :p
  10. Crmzendrgone
    Crmzendrgone Senior Member
    Apr 6, 2009
    3,218
    Mechanic. Mr. MOM
    Arizona
    Ok senese this thread is about plugs and there was an earlier argument over Brands of plugs. What has the most of the guys on here felt works best. I replaced my plugs with ACDelco they have seemed to have last for 50,000+- I know I need to replace them but not sure I want to use that brand again haven't decided. Also the gap I know the truck says whatever it says but has anyone ever played around with the gap to see?? I found that my 305 ran well at .030 or was it .035 one or the other but it was not the factory setting.
    Now for the Tstat you say 195 is that year specific or a good rule of thumb for all 350s TBIs
