Rebuilt Rochester 2B Carburetor - Now Idle Runs Very High
Discussion in 'Chevy Truck Forum' started by Lennie Friedman, Dec 10, 2017.
  1. MikeG
    2,803
    2,070
    Richland, Wa
    @Lennie Friedman Easiest way to check the base gasket it to spray a little Carb Cleaner around the base while the truck is running to see if the idle/ RPM's change. If it does increase, you found your leak.
    Lennie Friedman likes this.
  2. JTWard
    JTWard Full Member
    Sep 3, 2012
    1,257
    946
    I'm retired.
    Been years, but those old chokes linkages often got rusty or fouled with dirt and oil residue ?.
  3. Lennie Friedman
    Lennie Friedman Full Member
    Jan 7, 2017
    37
    General Manager for a High Tech Manufacturing Firm
    North Carolina
    Thanks fellas. I rebuilt the carb and certainly could have done something unitntentioanl to the choke.
    However it if is hot, and the throttle valve is wide open, would that choke cam still be affecting it?
  4. JTWard
    JTWard Full Member
    Sep 3, 2012
    1,257
    946
    I'm retired.
    Only if the choke , or it's linkage is holding it in a closed or partially closed position. To me I would think that would be a long shot. For example, if you hit the throttle pedal a couple of times as the engine was warmed up, then the choke SHOULD kick the choke open. This is something you would feel though Lennie.
  5. scavanger
    scavanger Full Member
    May 15, 2007
    1,763
    1,325
    does it only stall before it warms up ? when you say "throttle damper" do you mean the choke butterfly? If the choke is not set properly you can get to lean a mixture till the engine warms up. Cold engine requires richer mixture. check your linkage closely
    You may have the idle cam on incorrectly or some linkage on wrong causing the choke to not operate the way it should. This could cause it to be on the high idle at all times and it could cause stumble when cold due to the choke not being closed far enough. You may have to find a picture or another carb. to compare to.The choke/idle linkage can be confusing.
  6. Lennie Friedman
    Jan 7, 2017
    37
    North Carolina
    Got it. Thanks. It is possible I could have the linkage on incorrectly. I will take some photos to review.
    Appreciate your thoughts.
  7. leolkfrm
    12,741
    7,894
    sorry been plowing snow and running to the hospital,
    yes, look at the actual cam for choke, make sure the base idle screw is not resting on the first step of cam, it will raise the idle about 200 rpm
  8. Lennie Friedman
    Jan 7, 2017
    37
    North Carolina
    Awesome and Thanks.! To confirm, base idle is the high idle, or idle for the choke? Sorry to be a pain, but do you have a pic of what it should look like?
  9. scavanger
    May 15, 2007
    1,763
    1,325
  10. leolkfrm
    12,741
    7,894
    base idle is hot running idle, what you are trying to achieve
