oil pressure question
Discussion in 'Chevy Truck Forum' started by medic3616@sbcgl, Nov 8, 2007.
Thread Status:
Not open for further replies.
  1. medic3616@sbcgl
    medic3616@sbcgl Full Member
    Aug 31, 2007
    20
    paramedic
    my 95 K1500 350 ci has been dropping oil pressure when idling, the oil is full, when I tap the accelerator the pressure comes back to normal. is this something yo worry about?
  2. 75K30
    170
    Probably pretty normal. Chevies can run on very low pressures, and the loss of pressure at idle is very normal since the engine is not spinning the pump very fast.
    This only becomes a problem if and when the gauge gets to zero.
  3. brutis
    brutis Senior Member
    Oct 12, 2007
    67
    brooksville florida
    not quiet zero 7 lbs then you have to start thinking crank and new pump and everything else that intails
  4. scottie
    scottie Senior Member
    Jan 6, 2006
    644
    Mercedes Benz tech
    South Florida (Palm Beach), originally from south
    your oil pump is driven off the camshaft, so it is only natural that your pressure is directly related to your RPMs... my truck is the same way
  5. Donut John
    Donut John Full Member
    Jan 2, 2007
    Oil Pressure
    I had the same problem and it turned out to be the oil pressure sending unit. It's a relatively cheap fix. Or at least you can exclude the sender. I have an '88 C1500 and it was a fairly easy fix. Good luck
    Donut John
  6. 436'd skylark
    436'd skylark Senior Member
    1,143
    29
    Mac Tool Distributor
    Pennsyltucky
    How low does the pressure get? Low oil pressure is not good, but as long as you have 10 pounds at a hot idle, and the guage climbs right up on a rev you should be ok.
  7. medic3616@sbcgl
    Aug 31, 2007
    20
    paramedic
    pressure drops to about 10 but shoots right back up when reved
  8. sport
    sport Full Member
    Jun 25, 2007
    40
    my 92 does the same thing. Comes right back up when i give it gas.
  9. coltsfan
    coltsfan Member
    Jan 25, 2009
    Springfield, MO
    I have a 90 C1500, it's been dropping to about 25 lbs at idle, then jumps to about 30 when I accelerate.
  10. leolkfrm
    7,920
    This post is over a year old, wonder if the engine blew up by now!!!!!!!
    Someone lock it out
Thread Status:
