Odor in cab
Discussion in 'GMC Truck Forum' started by Bill736, Oct 13, 2011.
  1. Bill736
    Bill736 Full Member
    Jul 17, 2011
    49
    19
    Delaware
    My 2000 GMC Sierra is getting a musty, foul odor inside the cab. The same thing happened to my 1989 Chevy pickup a couple of years ago. When I turned a corner, I could hear water splashing around somewhere under the dash. I think that the problem is rain water that runs into the grill in front of the windshield, and gets trapped somewhere in the ventilation system. There must be a water drain somewhere, and maybe it's getting blocked with leaves . Where do I look for a drain to unclog ?
  2. gmctrucks
    9,132
    4,873
    On my 93 GMC truck the drain is on the outer firewall below A/C box it's just a black little tube if you can remove the hood grill do it and remove leaves from that area.
    Every chevy truck i have owned .. been quit a few has had water in the heater box. Go around curve.. stop here it slosh.
    Only way to get it out take heater box apart will drain. At wipers area/cowl there are some rubber looking plugs that is how water gets in.
