no fuel
Discussion in 'Ford Truck Forum' started by poppa, May 16, 2017.
  1. poppa
    poppa Full Member
    Apr 1, 2017
    35
    Hi , I replaced the fpdm (bad) and now , no start at all. I don't hear the initial fuel pump running when the key is turned on. Is there a fuse for the fuel pump , I can't find one for it. Can I check for power to the pump without dropping the tank? Ford F150 , 04 , 8 cylinder (daughters truck). Thanks
  2. jkeaton
    3,056
    5,114
    There has to be a fuse somewhere. Look harder.
  3. poppa
    poppa Full Member
    Apr 1, 2017
    35
    #3 poppa, May 16, 2017
    Nothing marked fuel pump
  4. gmctrucks
    8,576
    4,169
    #4 gmctrucks, May 16, 2017
    kbrown11 likes this.
  5. poppa
    poppa Full Member
    Apr 1, 2017
    35
    How do I test this "not removable" relay and how do I test the fuel pump itself (can this be done without tank removal)?? Thanks
