Need some input on pump options for my Used Engine Oil.
Discussion in 'General Truck Forum' started by Lonesome7.3, Dec 10, 2016.
  1. Lonesome7.3
    Lonesome7.3 Full Member
    Jul 21, 2008
    5,101
    994
    Columbus GA
    I have been looking at pneumatic diaphragm pumps for moving my dirty oil. I have found some on eBay that are pretty affordable. I am wondering is a $250 pump is going to work. That being said, I was looking at an electric sewage pump the other day at Harbor Freight. Plugging the pump into an electrical outlet would be so much more convenient. Would a sewage pump handle the harsh petroleum products in my dirty oil drums? If not, is there an electric alternative that can?
    I really prefer not to buy two pumps. Is there a way to use one pump for both? Maybe purging the dirty oil before pumping clean into my truck? Any input is appreciated.
    7,916
    i would not use the same pump for both
    there is an air venturi system that uses low pressure air to push the oil out
    what about a barrel rack and filler can?
  3. Lonesome7.3
    Jul 21, 2008
    5,101
    994
    Columbus GA
    The venturi system sounds interesting. I would really like a 12V pump. But I am not opposed to air. What do you mean by barrel rack and filler can?
  4. Lonesome7.3
    Jul 21, 2008
    5,101
    994
    Columbus GA
    I meant 110, not 12V. I would really like to just plug into an outlet in the shop.
  5. dirtrider73068
    6,923
    4,437
    I would get one made for transfer of oils if not it may mess up the pump not made for it.
  6. leolkfrm
    7,916
    [​IMG][​IMG]
  7. Lonesome7.3
    Jul 21, 2008
    5,101
    994
    Columbus GA
    I gatcha. That will not work. The system is gravity fed. Pouring oil in the high up dirty tank is a pain and messing. I have to pump it from the barrels.
