Name that part!
Discussion in 'GMC Truck Forum' started by SQBADOG, Feb 2, 2018.
  1. MikeG
    2,923
    2,165
    gmtruckclub.com
    Gasket for sure, I can’t see why the cover would need replacing unless it was damaged. I’ve never had a problem reusing the cover. Sounds like another way for the shops to rob more $ out of you.
  2. SQBADOG
    SQBADOG Full Member
    Jun 1, 2010
    312
    130
    City of Brotherly Hoods.
    Ok, so I found it in my Transmission PAN. Sorry. I have both pans dropped. Sorry...
  3. SQBADOG
    SQBADOG Full Member
    Jun 1, 2010
    312
    130
    Ok, so to back track. This started out as oil pump failure, had to pull oil pan, much easier to deal with pick up gasket incase it was that. Since it wasn't, then pulled timing cover. Was putting timing over back on when it cracked. Since I was waiting for new timing cover, dropped the tranny pan. That is where the spring came from. Make sense?
  4. MikeG
    2,923
    2,165
    gmtruckclub.com
    nope :rofl:
    Is your rig shifting like it should? I would suck if the Xmsn needed to be rebuilt do to a broken spring.
