Mazda B4000 Code P0133 and P0153 O2 slow response
Discussion in 'Mazda Truck Forum' started by rvogeler, Aug 1, 2015.
  1. rvogeler
    rvogeler New Member
    Aug 1, 2015
    Have a 1997 Mazda B4000, 4.0l, automatic, 2 wheel drive that is throwing codes P0133 and P0153. Both banks have slow response. When I do a live read of system, all 3 O2 sensors are showing 0.000 after running for 45 minutes and longer. Read somewhere else that it may be caused by some other place. Not sure what else to do or where to start. Any advice or direction?
    7,916
    sorry i no nothing about mazda, someone here will prob know but may take a bit since its the weekend, i am sure there is a way to check each sensor
    Same as ford..when searching info search ford same year..same engine..you have a scan tool..spray some carb. cleaner in throttle body..if voltages stays at 0 need 02 sensor.
  4. MrMarty51
    Also, the connectors might be dirty, or, disconnected.
    They can be checked with a volt meter too, while the engine is warming up.
  5. rvogeler
    rvogeler New Member
    Aug 1, 2015
    Thanks for your suggestions! Think I am having an issue with my Actron CP9580 not working 100% with my 97 truck. When I go to view data, that is where I see the O2 sensors reading 0.000 but also I have ST FTRM1 & 2, LT FTRM1 & 2 reading -100%. So something is definitely not reading right with my live data. But the codes P0133 and P0153 were both being thrown. Replaced the Bank 1 Sensor 1 and the P0133 cleared. After the P0153 popped up again, I replaced the Bank 2 Sensor 1 O2 sensor. All errors have cleaned and passed emissions test this morning with no check engine light on! No on to other repairs! Thanks again for advice and help!
    Far out ...thanks for posting back .
  7. MrMarty51
    Always nice when a repair falls into place.
    Thank You for reporting back the success.
