Gmc half ton conversion
Discussion in 'GMC Truck Forum' started by Liam, Dec 25, 2017.
  1. Liam
    Liam New Member
    Dec 25, 2017
    Hi, i just converted my 92 gmc sierra half ton to a three quarter ton when i straight axled it with some 78 ford axles. What i want to know is what are the best master cylinders that i could run for this conversion?
  2. greencamaro1981
    greencamaro1981 Full Member
    Feb 5, 2011
    476
    detention officer
    bozeman mt
    this just doesn't make any sense, you should run the master cylinder that came with the truck originally.
    7,919
    i would match the master to the brake system you are using, old one or converted one
  4. MikeG
    2,923
    2,165
    gmtruckclub.com
    If old one from "donor" doesn't work there are plenty of companies out there that sell brake kits or Adapter kits. Maybe looking into those or even contacting them would be a good start. Due to different types of conversions, the Off-Road aftermarket is huge.
  5. greencamaro1981
    Feb 5, 2011
    476
    detention officer
    bozeman mt
    the brakes are just a set of hydraulics, what most big off roaders do is purchase an adjustable proportioning valve to fine tune how much pressure you want where. with brakes start high then back off pressure. in the race cars we install knobs in the seat to adjust on the fly
