gmc electrical diagrams
Discussion in 'GMC Truck Forum' started by chevychase, Aug 13, 2013.
  1. chevychase
    Post as you find
    fonseca likes this.
    Go to chevy forum will be the same top of page sticky electrical diagrams.
  3. yann
    yann New Member
    Aug 27, 2014
    GMC t8500 headlight problem.
    [QUOTE = chevychase; 255052] 포스트를 찾을로 [/ QUOTE]
    please~help me.
    I'm looking for GMC T8500(2001) headlight wiring diagram.
    It's so hard to find.
    So it's urgent.
    Let us know any way to find~~~
    Turning on such a low even faintly illuminates such high.
    YOU ALL.....
  5. fonseca
    fonseca Member
    Oct 19, 2016
    truck-driver
    norway
    hi mate you know if is possible put a new wires from speed sensor from transfer-case to speedometer on suburban 95 6.5TD? i change a automatic transmission to full manual transmission and now not working a dam speedometer, cruise control, not start engine the ABS light is one!! a lot people make the same modification and i"m not find anny guy he can help me
  6. kyle8972335
    kyle8972335 New Member
    Feb 12, 2017
    Hey man I have a 1996 gmc sierra k1500 my tail lights will not work. I cut the wires infront of the tank. I have a LT. Green D. Green, Yellow, White, and I wanna say Brown. I took a harness off a 91 chevy Silverado k1500 it has black, lt. green, d. green and yellow. What do I hook up? Ive been fighting with this for a couple of days now. ive hooked yellow to yellow lt green to lt green, d green to black, grounded white, because when I took the wiring off white was not connected to anything, didn't know what to do with it
  7. gmctrucks
    9,131
    4,873
    Hey guys I don't know where I read this so I shared it with big bro so check it out guys oh below is what I sent my big brother.
    Take care! GMC
    The guy had removed his dash to replace it and his battery was going dead when he would drive it, so some guy wrote this below just sharing some info with you big bro.
    When you removed the dash, the idiot charge light indicator was remove, and that is known as the ticker wire... which excites the alternator into charge mode, if not a solid connection with resistance will not ever charge. find the excite wire , wire in a bulb @ 194 bulb or equal resistance and will go back to charging, I prefer a light on dash that way I know if its working or not. all over the internet of you Google it.
    Now this is me I had never heard of this but when one is having electrical problems it can be a royal pain in the rear that's why I said let me share this.
    Be safe! GMC
