Gear Ratio
Discussion in 'GMC Truck Forum' started by Donny, Mar 12, 2017.
  1. gmctrucks
    9,058
    4,797
    #21 gmctrucks, Mar 16, 2017
    Donny don't guess make sure so you know it's right on you don't have to remove the front cover to check what gears you have.
    Donny super easy instead of guessing and spending money if your not right just trying to help you.
    Good luck! GMC. :)
  2. Donny
    Donny Full Member
    Jan 9, 2015
    69
    88
    I appreciate all the help guys,I figured out about the rearend gears, still tryin to figure out the front, I found some #'s on the casing but no help on those. Im also trying to figure out if my truck has right transfer case or not. It says 2.72 ratio on it.The tape trick works fairly accurate?
    MrMarty51 likes this.
  3. Donny
    Donny Full Member
    Jan 9, 2015
    69
    88
    I agree!
  4. MrMarty51
    The T-Case should ave a round tag on the back side of the housing. I think it was the back side.
    It should have some numbers on it, with some letters.
    It should go something like NP241C or a NP243C etc.
  5. Donny
    Donny Full Member
    Jan 9, 2015
    69
    88
    The t-case is good. Im having an issue when ingaging into 4-low I have grinding, but 4-hi engages smooth like it's suppose to. Any suggestions?Thanks in advance.
  6. MrMarty51
    When it is grinding going into 4 low, is the vehicle moving ?
    I always have to come to a complete stop to get Mine to go into 4 low.
    If the trans is in neutral it will then grind too.
    Must be stopped in gear or stopped in park to go to 4 low.
  7. Donny
    Donny Full Member
    Jan 9, 2015
    69
    88
    Mine is always in neutral when I try to engage it,I thought it had to be in neutral to engage it. Will try it in gear to see how it does. Appreciate quick response MrMarty51
  8. Donny
    Donny Full Member
    Jan 9, 2015
    69
    88
    I tryed it in gear, no grinding! Appreciate it for the info.
