Gear Ratio
Discussion in 'GMC Truck Forum' started by Donny, Mar 12, 2017.
  1. Donny
    Donny Full Member
    Jan 9, 2015
    69
    88
    I have had it in 4wheel drive a few times, why?
    MrMarty51 likes this.
  2. Donny
    Donny Full Member
    Jan 9, 2015
    69
    88
    I looked on you tube, the only talk about the rear gear ratio, nothing on the front one.
  3. gmctrucks
    9,058
    4,797
    One axle is going to turn faster than the other one so one axle will be making a chirping sound which in time will break something
  4. Donny
    Donny Full Member
    Jan 9, 2015
    69
    88
    I have never heard a chirping sound, only thing I have noticed when I take it out of 4wheel drive, is sometimes I would get grinding somewhere in it.
  5. Donny
    Donny Full Member
    Jan 9, 2015
    69
    88
    That is why I think the front gears is factory 3.42 while the rear had 3.73 in it
    gmctrucks and MrMarty51 like this.
  6. dirtrider73068
    6,882
    4,393
    In a 4x4 if the two diff gears are not the same one turns faster another slower puts alot of stress on the gears, will tear stuff up, transfer case gears, diff gears will wear them out if not bind up and bust the gears.
  7. Donny
    Donny Full Member
    Jan 9, 2015
    69
    88
    Thats why I believe that my front is still 3.42, I bought the truck used 3yrs ago,my thought are that when they had truck redone after the accident it was in, they changed the rearend no knowing about the gears, lady owned it before me, gears do grind when I take it out of 4wheel drive, probably because of the 3.73 gears in the rearend, thats probably why the gears did bust,ring and pinion gear busted.Will go with the 3.42 gears in the rear also.
  8. dirtrider73068
    6,882
    4,393
    If the front is 3.42 then the rears need to be the same.
  9. MrMarty51
    If the rears is 3:42 and the front is 3:73, that thing will lock up and not move within twenty feet, or if You are getting on it, it will bust a gear, a U~Joint or any other number of given components.
    If Your vehicle did not bind to a stop then You gearing, front and rear, is the same.
    the old, real old 4X4s used to run 1 ratio higher in the front. if the rear was 4:10 then the front was 4:09. They did that so when slogging through the mud and snow, the front would be spinning and pulling faster than the rear end, for steering purposes. On thos old units, if You run them on hard pack for any distance whatever, they would bind up so bad that the would actually jump, and break things on the way there. It told right on the instructional sheet, on the dash or the sunvisor, to never run on solid surfaces when in four wheel drive.
    So, wioth that bit of knowledge, and those old units being just one number off, Your vehicle would not be able to move more than about fifteen or twenty feet without binding so bad that it would cease to move, unless You are really getting into the throttle, then something is going to bust.
    gmctrucks and leolkfrm like this.
  10. leolkfrm
    12,741
    7,896
    the grinding may be the actuater in the front axle not disengaging properly, might be getting weak, had that problem with a 92
