Gear Ratio
Discussion in 'GMC Truck Forum' started by Donny, Mar 12, 2017.
  1. Donny
    Donny Full Member
    Jan 9, 2015
    69
    88
    My 95 gmc z71 come out with 3.42 gears, my rear ring and pinion gear busted coming home one day. I took cover off and it has 3.73 gears in it. How can I tell if the previous owner changed front gears as well before I order new gears for the rear.
    MrMarty51 likes this.
    6,881
    4,393
    There is a way to count the teeth on each do a little math and tells you the gear ratio but that was way way back in the school days. Might look up google and see what you can find.
  3. Donny
    Donny Full Member
    Jan 9, 2015
    69
    88
    My front pumpkin doesnt have a cover to take off. Its kinda like a 2 piece front end on it. Ive tryed googling and havnt gotton any info from there. Cant find any tag or stamped #'s on it anywhere.
  4. leolkfrm
    12,741
    7,894
    check the build sheet in the glove box...might have been part of an option pkg
  5. Donny
    Donny Full Member
    Jan 9, 2015
    69
    88
    Will it be in one of the other RPO codes? That is how I found out that it come with 3.42 gears.
  6. leolkfrm
    12,741
    7,894
  7. Donny
    Donny Full Member
    Jan 9, 2015
    69
    88
    I did vin decoder.nothing helped.I uploaded my RPO to ya, I know the G80,and GU6.
  8. leolkfrm
    12,741
    7,894
  9. Donny
    Donny Full Member
    Jan 9, 2015
    69
    88
  10. gmctrucks
    9,057
    4,796
    Donny I would check to see if the front is 3.42 first because if it's 3.73 or if the changed out the whole front axle your going to have to redo your work look on You Tube how to check what you have.
    Another thing have you ever ran the truck on 4X4??
    MrMarty51 and leolkfrm like this.
