Front bumper jammed against right wheel
Discussion in 'Toyota Truck Forum' started by wilhed, Jan 1, 2017.
  1. wilhed
    wilhed Member
    Dec 30, 2016
    19
    machinist
    Seattle, WA
    Big snow fell on New Year's Day out here in Seattle and I ran into a parked semi and the right side of the bumper on my Toyota Tacoma SR5 4x4 is now jammed against the right front tire. Any thoughts on how to fix this? Crowbar, hammer, rubber mallet? The right turn signal also came undone but still works and fits in its housing.
    The valance is bent outward a bit.
    12,741
    7,896
    hook it to a tree and back up fast
    gmctrucks and Kennyray like this.
  3. dirtrider73068
    6,882
    4,393
    Find a good solid object a big tree or pole, hook up a chain or a winch of some sort and slowly pull it back, if using a chain and tree have somebody watching so you don't bend the bumper back too far or worse rip it off.
  4. wilhed
    wilhed Member
    Dec 30, 2016
    19
    machinist
    Seattle, WA
    Thank you I will try this!
  5. MikeG
    2,804
    2,070
    Richland, Wa
    Was a heck of a snow storm for sure. Instead of backing up, you could also use a Hi-Lift jack or a Come Along.
  6. wilhed
    wilhed Member
    Dec 30, 2016
    19
    machinist
    Seattle, WA
    #6 wilhed, Feb 3, 2017
    Hi-Lift Jack - pretty nifty tool: http://www.northerntool.com/images/downloads/manuals/1442.pdf.
    Not quite sure how it would bend out a bumper but here's what one reviewer wrote:
    &quotd
    Great for many different uses. My younger years when I worked in an auto parts yard I was introduced to the "Hi-Lift All Purpose Mechanical Jack. We use to use it for lifting a large hi-low truck for repairs etc.
    My brother uses this jack for removing the tires off his suburban rims by first removing all the air from tire then laying half the tire under the back of his work van and placing the jack directy on the tire as close as you can get the base of jack next to the rim while keeping the jack base directly on the rubber tire.
    He jacks the back of his van up n compresses the tire for removal. In my opinion and experience using n seeing this jack in action, it is a valuable tool to own.
    &quotd
  7. wilhed
    wilhed Member
    Dec 30, 2016
    19
    machinist
    Seattle, WA
  8. MikeG
    2,804
    2,070
    Richland, Wa
    #8 MikeG, Feb 3, 2017
    I think all H-Lifts are able to be used as a winch. I'll find a video and post it.
  9. MikeG
    2,804
    2,070
    Richland, Wa
    You could use this same principle with the strap around the bumper, and your rig locked down.
  10. gmctrucks
    9,057
    4,797
    Mike good idea I picked one up at a Pawn shop this thing was like almost brand new and priced cheap now I didn't need it but one can never ever have enough tools.
    Take care! GMC
