fan blower motor issue
Discussion in 'Chevy Truck Forum' started by 93bluesilverrad, Oct 12, 2017.
  1. 93bluesilverrad
    93bluesilverrad Full Member
    Dec 29, 2007
    429
    133
    all fan speeds work but don't seem as strong as they used to be, especially on high or low. since they work is there a way to test blower motor to see if it needs replaced, thanks.
    12,657
    7,766
    if you have one, check cabin air filter, try blowing the ducts out
    are flappers working correctly
    chevychase likes this.
  3. 93bluesilverrad
    Dec 29, 2007
    429
    133
    my bad 93 1500 no cabin filters, door fine just air seems weak
  4. gmctrucks
    8,744
    4,400
    Check this video out I bet your 93 needs the same thing done like my 93 so when your done come on over. :rofl:
  5. dirtrider73068
    6,729
    4,171
    I was gonna it could be the evap coils have junk stuck to them, like this leaves or whatever it may be the fan can suck into it. Most times just reaching in there and removing the junk by hand will work and help, they do have I think special cleaner for this like house hold ac unit called coil cleaner. You spray it on let it sit then wash it off, but before you squirt water in there make sure your drain is clear and is open or could fill up the ac box adn overflow into the cab on the floor.
    On these trucks to get the blower motor out is not as easy as his shows it can be a major PIA, you have to fandangle it out and fight with it some case you have to carefully squeeze on the fan cage to get out, just go easy as the cage could be brittle from the heat. Just take your time in removing the blower motor. Also check on top at the bottom of the windshield there is a screen there as well to help keep leaves and debri being sucked in by the fan it could also be covered up.
    chevychase, MikeG and gmctrucks like this.
  6. gmctrucks
    8,744
    4,400
    dr found this spray that one could use on home units at Home Depot I would say one could use it on our trucks since your going to rinse it off with a water hose and the spray isn’t that much and it does clean good.
    22,406
    13,171
    Might test the resistor....?? If resistor is getting old wore..might take 12 volt straight to the motor hot bypass resistor see if it blows more.
    MikeG, gmctrucks and 96silverado like this.
    22,406
    13,171
    Oh check the ground also.
  9. chevychase
    22,406
    13,171
  10. 96silverado
    96silverado Full Member
    Sep 23, 2012
    2,634
    3,708
    Sweet!!
    gmctrucks and chevychase like this.
