Engine Block Shipping
Discussion in 'GMC Truck Forum' started by timw128, Dec 19, 2016.
  1. timw128
    timw128 Full Member
    Sep 12, 2016
    71
    106
    33
    Retired Sr. Design Engineer at GM Tech Center
    MI
    Hello-
    Anyone have any suggestions for the cheapest, most effective way to ship a bare Chevrolet Small Block engine block across country?...
    Thanks-
    tim
  2. gmctrucks
    9,134
    4,877
    Yes ship it to a Fed/Ex and so on terminal instead of a house then you pick it up.
    timw128 likes this.
  3. dirtrider73068
    6,923
    4,437
    Need a good solid crate to bolt it to cover it and seal it, will need to ship it ground frieght will need to go on a truck, going to cost a bit to ship it, unless find a trustworthy hotshot service going the direction it needs to be shipped that could pick it up and haul it.
    timw128 likes this.
  4. timw128
    timw128 Full Member
    Sep 12, 2016
    71
    106
    33
    MI
    Yeah, $200+... that's ridiculous. Block's not worth it.
  5. timw128
    timw128 Full Member
    Sep 12, 2016
    71
    106
    33
    MI
    Yeah, prices range from $200+ to $600+...that's just ridiculous for a bare block, IMO. Used to find 4 bolt main blocks in the bone yard for $50-$100 before Osambo's 'cash for clunkers' program. Not any more...they've become as rare as hen's teeth.
  6. gmctrucks
    9,134
    4,877
    Can't you get one close to where you live I'm wondering if you don't mind why do you want that one block?
    I'm wondering if you can have a bus take it to your local terminal?
    timw128 likes this.
  7. timw128
    timw128 Full Member
    Sep 12, 2016
    71
    106
    33
    MI
    Because the block was offered to me, no charge, and it's a 4 bolt main, 010-020 casting- meaning it's a high tin, high nickel piece.
    I live at the center of the automotive industry and small block Chevy engines, blocks, cylinder heads, etc. used to be a dime a dozen at the many salvage yards. The auto salvage facilities were full of them, and good blocks went for as little as $50.
    They simply don't have them anymore.
    GM Performance, Summit, World, etc. offer the SB1 block castings with a minimum .030" overbore- which tells me they are most probably recon blocks. They start at approx. $750.
    Greyhound bus lines has a weight limit of 100 lbs. An engine block exceeds that by 50-60 lbs.
  8. leolkfrm
    7,916
    take a vacation to an area that you find them in, there are still around ny, maybe locate one and take the wife to the finger lakes for a wine tour
  9. dirtrider73068
    6,923
    4,437
    But that 200 plus shipping might be worth it if you clean the block up and build it and resale it. Unless you want the block for yourself. Why I mentioned a hot shot service thats in the area of the block thats traveling your way can pick it up and drop it off or at least get close like say 100 miles then drive to get it.
