Electrical diagrams chevy only
Discussion in 'Chevy Truck Forum' started by chevychase, Aug 13, 2013.
  1. hatzie
    hatzie Full Member
    Mar 17, 2014
    399
    732
    Northern New England
    MediaFire 1994 GM Light Truck Manuals
    chevychase, MrMarty51 and timw128 like this.
  2. timw128
    timw128 Full Member
    Sep 12, 2016
    71
    106
    33
    Retired Sr. Design Engineer at GM Tech Center
    MI
    Many thanks, hatzie! :bow:... I'll check it out. I just found the holy grail over on CC's Electrical Diagrams thread- that PDF with the codes and diagnostics on the 4L60E from those Brits (ATSG) :applaud:... replaced ground straps, found one broken, and giving the Ignition Switch another hard thought or two.... am going to run right through the initial battery checks and then the diagnostics for the 4 DTC's I mentioned above.
    Again, thanks...Have a great weekend. :woot:
    chevychase and MrMarty51 like this.
  3. bikernut
    bikernut Full Member
    Jan 26, 2008
    91
    looking for a rear wiring harness and diagram for a 2003 Chevy/GMC reg cab 3500 with dual fuel tanks cab & chassis. where it originates from in the front to the rear connector on rear cross member and where can I purchase one with out giving up my pension check? thanks
  4. Kennyray
    Kennyray Moderator
    Oct 6, 2005
    2,028
    2,372
    Fort Wayne, IN
    Did you go through everything is this thread?
  5. bikernut
    Jan 26, 2008
    91
    I went thru all 13 pages and didn't find anything for a rear wiring schematic I was looking for in my vehicle
    96silverado likes this.
  7. gmctrucks
    9,131
    4,873
    Guys I don't want to start a new thread just for what I want to know so here it goes will a 7443 bulb work for my rear taillight signal light on my 1993 F/S GMC truck?
    Thanks! GMC :)
  8. gmctrucks
    9,131
    4,873
    Guys why I wanted it to work because it blinks several times before it just stays on solid would you guys know of a bulb that would work on my truck and do what I want?
    I know Ebay has this blinker dealy but I want just a plug and play bulb.
    Thanks again! GMC
  9. DannyCO
    DannyCO Full Member
    Jul 7, 2014
    72
    85
    Colorado
    I've looked through this thread and haven't found what I'm looking for. I'm looking for a wiring diagram for the fuel pump on a 1990 GMC S15. I also need to know where the fuel pump relay is on this truck.
  10. livechevy
    livechevy New Member
    Dec 31, 2016
    Railroad
    Missouri
    Such great info to know! Thanks chevychase! Just one question, is this for the ECM and engine wiring only? I just tried to look up a part number for 1993 and 1995 ECM and the site ( o'reillys I think ) gave different part numbers for the ECM's. I have a 1993 Sierra that I am wanting to upgrade the dash and other interior parts on.
    Again, thanks for your hard work!
