Diesel Jeep Project
Discussion in '4x4 trucks / off road' started by Mike_955, Dec 31, 2016.
Tags:
  1. Mike_955
    Mike_955 New Member
    Dec 31, 2016
    I am thinking about taking a late 90s Jeep Cherokee and putting a diesel motor and drivetrain in it. Any suggestions on a diesel motor? Thinking a 4 cylinder motor. Or there may be a better motor cylinder configuration.
    This truck is going to be like a trail truck. Although not lifted high or super big tires. It will have lots of highway miles put on it. A range of about 300+ miles is needed (with 1/4 fuel remaining). This would be for the mountain adventures in the state of Washington.
    Thank you,
    Mike
  2. kbrown11
    kbrown11 Full Member
    Dec 5, 2015
    1,223
    2,143
    Alburquerque
    Cummins will be coming out with a drop in crate diesel engine for jeeps.
  3. kbrown11
    Dec 5, 2015
    1,223
    2,143
    Alburquerque
    This video is a commercial for the cummins engine:
  4. greencamaro1981
    greencamaro1981 Full Member
    Feb 5, 2011
    475
    111
    detention officer
    bozeman mt
    perkins 4cyl most common 4 cyl in cat/case/ih backhoe/tractors small and easy to find parts for
  5. kbrown11
    Dec 5, 2015
    1,223
    2,143
    Alburquerque
    I would also think about the transmission that you will put with the engine. Would you like a manual or auto? The other speed bump would be if the transfer case can be mounted on the new transmission on the driver side of the Cherokee. Your Cherokee's front drive shaft is on the driverside, the punkin/differential are driverside. If you can't mount the transfer case to work with the current front axle you will have to swap out the front axle as well.
  6. batty1214
    batty1214 Full Member
    Nov 2, 2008
    2,276
    510
    Mine Mechanic(tire guy)
    Vernal Utah
    A common Toyota mini truck swap is the Volkswagen diesel from a jetta. I don't know too much about it other than it is a smaller, capable engine, that would be about the right size for a Cherokee.
    kbrown11 likes this.
