Chevy automatic 4x4 actuator/selenoid?
Discussion in '4x4 trucks / off road' started by shadygrady, Feb 3, 2008.
  1. chevychase
    Sheesh they sound worse than monkeys ..monkey do better than that. Hey check the ground for the 4x4 system..follow harness to ground ..think it is on driver side frame. Will have grounds on intake at thermostat area and maybe behind the ac pump. Just run a ground from engine to chassi and frame that you can see. More grounds the merrier..you should see a state police car ..grounds everywhere i mean all over but the need for radios lights ect.
    If you read link i left maybe ground location for 4x4 system in it.
  2. calisdad
    calisdad Full Member
    Oct 17, 2010
    151
    70
    retired home builder
    groveland, ca
    Unbelievable! I disconnected my batteries for a few hours and when I reconnected them everything worked!
    Rebooted the trucks computer I suppose.
  3. calisdad
    Oct 17, 2010
    151
    70
    groveland, ca
    Thanks Chevychase. You bet I'll be going over them and adding some. What a relief! whew.
    Your more than welcome calisdad..you sure need to find diff mechanics /monkeys !!! Who is Cali the dog in advatar?
  5. calisdad
    Oct 17, 2010
    151
    70
    groveland, ca
    That's Bodacious- aka Bodie. Handsome Brothers.jpg He's quite the tournament hunter as is his brother Trapper. Cali was a previous springer I had the good fortune to raise.
    Hey some good looking kids/dogs you train?
  7. calisdad
    Oct 17, 2010
    151
    70
    groveland, ca
    Thanks- I train mine, as best I can. We do a little work most every day and hunt quail and pheasant when the season comes around. Tournament hunting extends our season a bit. They have a wall of trophy's and ribbons and are only 3 and 4. Its pretty cool when they come home with both 1st and 2nd. :D (Now if fixing my truck was only so easy- lol)
    Nice wall of ribbons and plaques Calisdad
  9. A1steaksauce
    A1steaksauce New Member
    Jan 5, 2014
    registered to say thanks to all those in this thread that have provided info in the past. was able to quickly and easily diag and fix my nonworking 4wd today.
    i have a 95 k2500 that wasn't going into 4wd. fuse for 4wd was good and fluid levels were fine in both front axle and transfer case. put the truck into 4wd, turned the key to on, and then crawled underneath. wasn't able to turn the front driveshaft so i was able to rule out the ball switch. double checked that i had 12v at the actuator, which i did, then i pulled it and bench tested. putting 12v to the actuator did absolutely nothing so off to the parts store i went. it really was a 5 minute job to install the new actuator and now my 4wd works flawlessly. thanks again everyone. it honestly took me longer to run to the parts store for a new actuator than it did to diag the 4wd. i'm ready for the snow now ;)
    3 people like this.
  10. MrMarty51
    :rofl::rofl::rofl:
    I like that, Welcome to the forum. Stick around and Youuuhhh tooo`ll get to know a lot about Your 95.
    Any more pwoblemz, come on back, but, if Yuh sticks around, Yuh`ll get a lot of "LIKES", I knows I doo an nobody likes Meee, well, here where i lives anyhows. :no: :rofl: just kiddingk.
