chevy 4x4 1500 5.7 1997 need wiring schematics for ecm and dignostic terminal
Discussion in 'Chevy Truck Forum' started by snyper123, Aug 7, 2013.
  1. snyper123
    snyper123 New Member
    wv
    have 97 1500 4x4 runs fine 110k but service engine light comes on sometimes used 2 scan tools to try get codes but one say voltage to high and will not communicate the other just will not comm. found pin 2 at dianostic port to have 10.4 volts switch on only also found fuse type diod in engine comp. fuse box that is lable diode 2 but thew only one used when removed pin 2 has 2.4 volts got another diod from 5.7 truck compared readings with old diodew both check good for no reverse voltage but the voltage thru side old one has 1.6m ohms and other one has 1.95m ohms 350,000m more when put the second one in switch on pin 2 had 2.4 volts for about 15 min then went to 10.4 volts recheck diode still has same readings as before was told that pin 2 should be 2 volts with diode removed has 2.4 but tools still will not communicate with ecm
  2. gpmorgan
    gpmorgan Auto Banned
    Nov 21, 2009
    2,687
    288
    83
    forklifts and equip tech
    Tupelo Ms.
  3. gpmorgan
    Nov 21, 2009
    2,687
    288
    83
    Tupelo Ms.
  4. gpmorgan
    Nov 21, 2009
    2,687
    288
    83
    Tupelo Ms.
  5. gpmorgan
    Nov 21, 2009
    2,687
    288
    83
    Tupelo Ms.
  6. gpmorgan
    Nov 21, 2009
    2,687
    288
    83
    Tupelo Ms.
  7. gpmorgan
    Nov 21, 2009
    2,687
    288
    83
    Tupelo Ms.
    #8 chevychase, Aug 7, 2013
    Are you sure your using the right scan tool? OnBoardDiagnostics.com - OBD-II Network Standards
    All it says voltage to high? maybe code is voltage too high? Take it to auto parts for a free scan..see what their says?? click on blue links www.troubleshootmyvehicle.com/gm/4.3L-5.0L-5.7L
    /pcm-connector-pin-outs-1996-1997-page-1
    Pin 10 is a floating ground for pin 2 check voltage on pin 2 with key on.
    This will be interesting why pin 2 has high voltage?
    Use a digital voltmeter to check the DLC connector:
    1. Check ground continuity. Connect the positive
    (+) meter lead to DLC pin 4. Connect the
    negative (-) meter lead to the negative battery terminal. Use jumper wires as needed. Do
    741
    not connect to a body or chassis ground; go di
    rectly to the battery terminal if at all
    possible.
    With the ignition on, voltage drop across the ground terminal should be 0.1 V or less.
    Repeat for DLC pin 5. An open circuit or high ground resistance prevents the ECM from
    entering diagnostic mode.
    2. Check voltage on pin 2 of the DLC. The PCM transmits data on this pin. Connect the
    positive voltmeter lead to the class 2 serial da
    ta pin and the negative lead to either pin 4,
    pin 5, or a known good ground. With the ignition on, voltage on the class 2 serial data pin
    should be either 5 V or fluctuating between
    3.5 and 5.0 V. If the circuit is open, the ECM
    cannot transmit data to the scan tool.
  9. chevychase
    [TABLE]
    [TR]
    [TH="colspan: 7, align: center"][FONT=Trebuchet MS, Arial, Helvetica] [/FONT][/TH]
    [/TR]
    [TR]
    [TH="colspan: 3, align: center"][FONT=Trebuchet MS, Arial, Helvetica]Connector Part Information[/FONT][/TH]
    [TH="colspan: 4, align: left"][FONT=Trebuchet MS, Arial, Helvetica] [/FONT][TABLE]
    [TR]
    [TD="width: 42"][​IMG][/TD]
    [TD="width: 100%"][FONT=Trebuchet MS, Arial, Helvetica]12129025 [/FONT][/TD]
    [/TR]
    [TR]
    [TD="width: 100%"][FONT=Trebuchet MS, Arial, Helvetica]Blue C1 32 Pin Connector [/FONT][/TD]
    [/TR]
    [/TABLE]
    [/TR]
    [TR]
    [TH="align: center"][FONT=Trebuchet MS, Arial, Helvetica]Pin[/FONT][/TH]
    [TH="align: center"][FONT=Trebuchet MS, Arial, Helvetica]Wire Color[/FONT][/TH]
    [TH="align: center"][FONT=Trebuchet MS, Arial, Helvetica]Circuit No.[/FONT][/TH]
    [TH="align: center"][FONT=Trebuchet MS, Arial, Helvetica]Function[/FONT][/TH]
    [TH="align: center"][FONT=Trebuchet MS, Arial, Helvetica]Component Connector Cavity[/FONT][/TH]
    [TH="align: center"][FONT=Trebuchet MS, Arial, Helvetica]DTC(s) Affected[/FONT][/TH]
    [TH="align: center"][FONT=Trebuchet MS, Arial, Helvetica]Possible Symptoms From a Faulty Circuit[/FONT][/TH]
    [/TR]
    [TR]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]1[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]--[/FONT][/TD]
    [TD="align: left"][FONT=Trebuchet MS, Arial, Helvetica]Not Used[/FONT][/TD]
    [/TR]
    [TR]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]2[/FONT][/TD]
    [/TR]
    [TR]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]3[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]BRN/WHT[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]633[/FONT][/TD]
    [TD="align: left"][FONT=Trebuchet MS, Arial, Helvetica]1X CMP Signal[/FONT][/TD]
    [/TR]
    [TR]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]4[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]PNK[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]539[/FONT][/TD]
    [TD="align: left"][FONT=Trebuchet MS, Arial, Helvetica]Ignition Feed[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]No Change[/FONT][/TD]
    [/TR]
    [TR]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]5[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]YEL/BLK DK BLU/WHT[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]846 878[/FONT][/TD]
    [TD="align: left"][FONT=Trebuchet MS, Arial, Helvetica]Injector # 6 Control (1) Injector #8 Control (2)[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]Rough Idle[/FONT][/TD]
    [/TR]
    [TR]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]6[/FONT][/TD]
    [/TR]
    [TR]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]7[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]TAN[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]1667[/FONT][/TD]
    [TD="align: left"][FONT=Trebuchet MS, Arial, Helvetica]H02S Low Bank 2 Sensor 1[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]Fixed H02S Reading[/FONT][/TD]
    [/TR]
    [TR]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]8[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]PNK/BLK[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]632[/FONT][/TD]
    [TD="align: left"][FONT=Trebuchet MS, Arial, Helvetica]CMP Low[/FONT][/TD]
    [/TR]
    [TR]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]9[/FONT][/TD]
    [/TR]
    [TR]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]10[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]TAN/BLK[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]422[/FONT][/TD]
    [TD="align: left"][FONT=Trebuchet MS, Arial, Helvetica]TCC Solenoid Control (7)[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]No TCC[/FONT][/TD]
    [/TR]
    [TR]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]11[/FONT][/TD]
    [/TR]
    [TR]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]12[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]DK GRN/ WHT[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]428[/FONT][/TD]
    [TD="align: left"][FONT=Trebuchet MS, Arial, Helvetica]EVAP Purge Solenoid Control[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]Purge Inop.[/FONT][/TD]
    [/TR]
    [TR]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]13[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]WHT[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]687[/FONT][/TD]
    [TD="align: left"][FONT=Trebuchet MS, Arial, Helvetica]3-2 Control Solenoid (5)[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]Incorrect Gear State[/FONT][/TD]
    [/TR]
    [TR]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]14[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]BRN[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]436[/FONT][/TD]
    [TD="align: left"][FONT=Trebuchet MS, Arial, Helvetica]AIR Relay Control (3)[/FONT][/TD]
    [/TR]
    [TR]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]15[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]696[/FONT][/TD]
    [TD="align: left"][FONT=Trebuchet MS, Arial, Helvetica]VSS Output Signal (Antilock)[/FONT][/TD]
    [/TR]
    [TR]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]16[/FONT][/TD]
    [/TR]
    [TR]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]17[/FONT][/TD]
    [/TR]
    [TR]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]18[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]GRY[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]435[/FONT][/TD]
    [TD="align: left"][FONT=Trebuchet MS, Arial, Helvetica]EGR Control[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]EGR Inop.[/FONT][/TD]
    [/TR]
    [TR]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]19[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]PPL/WHT[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]1665[/FONT][/TD]
    [TD="align: left"][FONT=Trebuchet MS, Arial, Helvetica]H02S High Bank 1 Sensor 1[/FONT][/TD]
    [/TR]
    [TR]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]20[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]PPL[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]1670[/FONT][/TD]
    [TD="align: left"][FONT=Trebuchet MS, Arial, Helvetica]H02S High Bank 1 Sensor 2 [/FONT][/TD]
    [/TR]
    [TR]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]21[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]1666[/FONT][/TD]
    [TD="align: left"][FONT=Trebuchet MS, Arial, Helvetica]H02S High Bank 2 Sensor 1 [/FONT][/TD]
    [/TR]
    [TR]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]22[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]1668[/FONT][/TD]
    [TD="align: left"][FONT=Trebuchet MS, Arial, Helvetica]H02S Bank 1 Sensor 3 (4) H02S High Bank 2 Sensor 2 (9) [/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]Poor Performance[/FONT][/TD]
    [/TR]
    [TR]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]23[/FONT][/TD]
    [/TR]
    [TR]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]24[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]1671[/FONT][/TD]
    [TD="align: left"][FONT=Trebuchet MS, Arial, Helvetica]H02S Low Bank 1 Sensor 2[/FONT][/TD]
    [/TR]
    [TR]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]25[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]TAN/WHT[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]1653[/FONT][/TD]
    [TD="align: left"][FONT=Trebuchet MS, Arial, Helvetica]H02S Low Bank 2 Sensor 2 (9) H02S Low Bank 1 Sensor 1[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica] [/FONT][/TD]
    [/TR]
    [TR]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]26[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]1669[/FONT][/TD]
    [TD="align: left"][FONT=Trebuchet MS, Arial, Helvetica]H02S Low Bank 1 Sensor 3 (4) H02S Low Bank 2 Sensor 2 (9)[/FONT][/TD]
    [/TR]
    [TR]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]27[/FONT][/TD]
    [/TR]
    [TR]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]28[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]574[/FONT][/TD]
    [TD="align: left"][FONT=Trebuchet MS, Arial, Helvetica]CKP Low[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]No Start[/FONT][/TD]
    [/TR]
    [TR]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]29[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]LT.GRN/BLK[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]822[/FONT][/TD]
    [TD="align: left"][FONT=Trebuchet MS, Arial, Helvetica]VSS Low[/FONT][/TD]
    [/TR]
    [TR]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]30[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]821[/FONT][/TD]
    [TD="align: left"][FONT=Trebuchet MS, Arial, Helvetica]VSS Signal[/FONT][/TD]
    [/TR]
    [TR]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]31[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]YEL[/FONT][/TD]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]573[/FONT][/TD]
    [TD="align: left"][FONT=Trebuchet MS, Arial, Helvetica]3X CKP Signal (1) 4X CKP Signal (2) [/FONT][/TD]
    [/TR]
    [TR]
    [TD="align: center"][FONT=Trebuchet MS, Arial, Helvetica]32[/FONT][/TD]
    [/TR]
    [/TABLE]
  10. chevychase
    [TABLE]
    [TR]
    [TH="colspan: 3, align: center"]Connector Part Information
    [/TH]
    [TH="colspan: 4, align: left"][TABLE]
    [TR]
    [TD][​IMG][/TD]
    [TD="width: 100%"]12129025
    [/TD]
    [/TR]
    [TR]
    [TD="width: 100%"]Red C2 32 Pin Connector [/TD]
    [/TR]
    [/TABLE]
    [/TH]
    [/TR]
    [TR]
    [TH="align: center"]Pin[/TH]
    [TH="align: center"]Wire Color[/TH]
    [TH="align: center"]Circuit No.[/TH]
    [TH="align: center"]Function[/TH]
    [TH="align: center"]Component Connector Cavity[/TH]
    [TH="align: center"]DTC(s) Affected[/TH]
    [TH="align: center"]Possible Symptoms From a Faulty Circuit[/TH]
    [/TR]
    [TR]
    [TD="align: center"]1[/TD]
    [TD="align: center"]--[/TD]
    [TD="align: left"]Not Used [/TD]
    [/TR]
    [TR]
    [TD="align: center"]2[/TD]
    [TD="align: left"]Not Used[/TD]
    [/TR]
    [TR]
    [TD="align: center"]3[/TD]
    [TD="align: center"]BLK[/TD]
    [TD="align: center"]1744[/TD]
    [TD="align: left"]Injector # 1 Control[/TD]
    [TD="align: center"]Rough Idle[/TD]
    [/TR]
    [TR]
    [TD="align: center"]4[/TD]
    [TD="align: center"]YEL/BLK[/TD]
    [TD="align: center"]1223[/TD]
    [TD="align: left"]2-3 Shift Solenoid Control (5) [/TD]
    [TD="align: center"]Incorrect Gear State[/TD]
    [/TR]
    [TR]
    [TD="align: center"]5[/TD]
    [/TR]
    [TR]
    [TD="align: center"]6[/TD]
    [TD="align: center"]LT/GRN[/TD]
    [TD="align: center"]1222[/TD]
    [TD="align: left"]1-2 Shift Solenoid Control (5)[/TD]
    [/TR]
    [TR]
    [TD="align: center"]7[/TD]
    [TD="align: center"]BRN[/TD]
    [TD="align: center"]418[/TD]
    [TD="align: left"]PWM TCC Solenoid Control (6) [/TD]
    [TD="align: center"]TCC Inop.[/TD]
    [/TR]
    [TR]
    [TD="align: center"]8[/TD]
    [/TR]
    [TR]
    [TD="align: center"]9[/TD]
    [TD="align: center"]DK GRN/WHT[/TD]
    [TD="align: center"]459[/TD]
    [TD="align: left"]A/C Relay Enable Relay Control[/TD]
    [TD="align: center"]A/C Inop.[/TD]
    [/TR]
    [TR]
    [TD="align: center"]10[/TD]
    [TD="align: center"]1456[/TD]
    [TD="align: left"]EGR Pintle Position[/TD]
    [TD="align: center"]EGR Inop.[/TD]
    [/TR]
    [TR]
    [TD="align: center"]11[/TD]
    [TD="align: center"]LT GRN/BLK[/TD]
    [TD="align: center"]1745[/TD]
    [TD="align: left"]Injector #2 Control (2)[/TD]
    [/TR]
    [TR]
    [TD="align: center"]12[/TD]
    [TD="align: center"]RED/BLK[/TD]
    [TD="align: center"]877[/TD]
    [TD="align: left"]Injector #7 Control[/TD]
    [/TR]
    [TR]
    [TD="align: center"]13[/TD]
    [TD="align: center"]LT GRN/WHT[/TD]
    [TD="align: center"]1749[/TD]
    [TD="align: left"]IAC B High[/TD]
    [/TR]
    [TR]
    [TD="align: center"]14[/TD]
    [TD="align: center"]LT BLU/WHT[/TD]
    [TD="align: center"]1747[/TD]
    [TD="align: left"]IAC A High[/TD]
    [/TR]
    [TR]
    [TD="align: center"]15[/TD]
    [TD="align: center"]LT GRN/BLKBLK/WHT[/TD]
    [TD="align: center"]1745845[/TD]
    [TD="align: left"]Injector #2 Control (1)Injector # 5 Control (2)[/TD]
    [/TR]
    [TR]
    [TD="align: center"]16[/TD]
    [TD="align: center"]PNK/BLKYEL/BLK[/TD]
    [TD="align: center"]1746846[/TD]
    [TD="align: left"]Injector #3 Control (1)Injector #6 Control (2)[/TD]
    [/TR]
    [TR]
    [TD="align: center"]17[/TD]
    [/TR]
    [TR]
    [TD="align: center"]18[/TD]
    [/TR]
    [TR]
    [TD="align: center"]19[/TD]
    [TD="align: center"]DK/BLU[/TD]
    [TD="align: center"]496[/TD]
    [TD="align: left"]KS Signal[/TD]
    [TD="align: center"]Knock Retard[/TD]
    [/TR]
    [TR]
    [TD="align: center"]20[/TD]
    [/TR]
    [TR]
    [TD="align: center"]21[/TD]
    [TD="align: center"]432[/TD]
    [TD="align: left"]MAP Signal[/TD]
    [TD="align: center"]Poor Performance[/TD]
    [/TR]
    [TR]
    [TD="align: center"]22[/TD]
    [TD="align: center"]TAN[/TD]
    [TD="align: center"]472[/TD]
    [TD="align: left"]IAT Signal[/TD]
    [/TR]
    [TR]
    [TD="align: center"]23[/TD]
    [TD="align: center"]YEL[/TD]
    [TD="align: center"]410[/TD]
    [TD="align: left"]ECT Signal[/TD]
    [/TR]
    [TR]
    [TD="align: center"]24[/TD]
    [TD="align: center"]417[/TD]
    [TD="align: left"]TP Signal[/TD]
    [TD="align: center"]Poor Performance/ Harsh Shifts[/TD]
    [/TR]
    [TR]
    [TD="align: center"]25[/TD]
    [/TR]
    [TR]
    [TD="align: center"]26[/TD]
    [/TR]
    [TR]
    [TD="align: center"]27[/TD]
    [TD="align: center"]1227[/TD]
    [TD="align: left"]TFT Signal (5)[/TD]
    [TD="align: center"]Early TCC[/TD]
    [/TR]
    [TR]
    [TD="align: center"]28[/TD]
    [TD="align: center"]492[/TD]
    [TD="align: left"]MAF Signal[/TD]
    [/TR]
    [TR]
    [TD="align: center"]30[/TD]
    [TD="align: center"]LT BLU/BLK[/TD]
    [TD="align: center"]1748[/TD]
    [TD="align: left"]IAC A Low[/TD]
    [/TR]
    [TR]
    [TD="align: center"]31[/TD]
    [TD="align: center"]BLK/WHTLT BLU/BLK[/TD]
    [TD="align: center"]845844[/TD]
    [TD="align: left"]Injector #5 ControlInjector #4 Control (2)[/TD]
    [/TR]
    [TR]
    [TD="align: center"]32[/TD]
    [TD="align: center"]LT BLU/BLKPNK/BLK[/TD]
    [TD="align: center"]8441846[/TD]
    [TD="align: left"]Injector #5 Control (1)Injector #3 Control (2)[/TD]
    [/TR]
    [TR]
    [TD="colspan: 7, align: left"][/TD]
    [/TR]
    [/TABLE]
