Changed steering column 1998 GMC Sierra
Discussion in 'GMC Truck Forum' started by gm truck guy, Dec 12, 2017.
  1. gm truck guy
    gm truck guy New Member
    Dec 12, 2017
    Hi I’m new here any help is greatly appreciated. I put the steering column from a 1996 Sierra into a 1998 Sierra bolted up fine everything fit. But now I’m having security issues truck starts but won’t keep running. So my question is how do I get around this? Is it possible to over ride the security somehow? Or do I need to get a different column and if so can anyone tell me what Year’s will work? Thanks.
    6,924
    4,440
    Did you swap out your key switch into the 96 column? It could be a chipped key its not picking up, or maybe the ignition switch. There is a way to bypass the security using a certain resistor you solder in a wire under the dash, google bypassing gm security for year of truck should find lots of info and vids on how to do it.
  3. dirtrider73068
    6,924
    4,440
    Or maybe have to do a security relearn prodcedure there is info on google on how to do that as well.
  4. gm truck guy
    Dec 12, 2017
    no the key switch was hammered Ive done some more research and it looks like Im going to need a column from a 1998 truck thanks for your time I'll let you know how this gets resolved
  5. greencamaro1981
    greencamaro1981 Full Member
    Feb 5, 2011
    476
    detention officer
    bozeman mt
    you can use the 96 column just have to bypass the security key
