Burning smell
Discussion in 'Mazda Truck Forum' started by TrucksGetDirty, May 16, 2008.
  1. TrucksGetDirty
    TrucksGetDirty Full Member
    May 9, 2008
    Florida
    Whenever my truck has been running for more then about a min, it will start to smell like burning radiator fluid. I have already changed the hose and did a clean out. I can't figure it out... I know there is a leak somewhere because I can see random white liquid drips (I will get a picture of it) and build up of coolant (or some yellowish/clear liquid) where the truck has been sitting. Also the truck idlies very fast and sounds like it is studdering with a weird ticking noise. Although it will start and run fine.
    Any ideas?
  2. mrjohnwayne
    mrjohnwayne Full Member
    Apr 15, 2005
    4,062
    101
    Oil and Gas field
    hmm. I would say waterpump but that doesnt account for the burning smell... have you checked the hoses where they go into the firewall for the heater core? That could cause a drip on to the exhaust creating the burning smell..
  3. Pantharen
    Pantharen Senior Member
    May 6, 2008
    207
    North Vancouver, BC. Canada
    For a B3000, this is a Ford Ranger engine. It could be just about anything.
    Get it up on a hoist, and see where it is dripping from, it is probably splashing onto the exhaust manifold from just about anywhere.
    For the fast idle, that could be timing, it could be loose linkage (common problem with Rangers & 1993+ Mazda's), it could be your idler is off, get a haynes/chilton manual. :D
  4. junior3382
    junior3382 Senior Member
    3,171
    89
    if it is a small leak, it will be hard to see.... Ususal suspects are where the rubber meet the steel, tends to rot more there. Lots of spots though... john is right, heater core is the best shot. But there are a dozen hoses carrying this fluid, could be anyof them...
  5. Pantharen
    May 6, 2008
    207
    You can buy a dye that you can put in your rad to find a leak. It'll turn your coolant a fluorescent orange color and alot easier to see than the green. It wont effect the coolant at all.
  6. TrucksGetDirty
    May 9, 2008
    Florida
    Thank you for the suggestions.
    I will be sure to try them all out.
  7. Chevy_Finatic79
    Chevy_Finatic79 Senior Member
    Mar 30, 2008
    494
    38
    Self Employed Mechanic
    Lincoln NE
    what year make and model is the leaking truck? a bad heater core usually is noticed by a foggy window or coolant fluid on the passenger side floor. I hate that burnt sugar smell I hope you figure it out
  8. TrucksGetDirty
    May 9, 2008
    Florida
    It is a 2001 Mazda B3000
  9. chankee
    chankee Full Member
    Sep 11, 2008
    20
    #9 chankee, Oct 6, 2008
    Clutches?Some rubber underneath the truck. That's bad, maybe some parts will be affected by that and the next time you knew it, it would be a serious prob. Exhaust do really smell bad, but it's worst when you can smell it while inside the ride.
  10. leolkfrm
    12,741
    7,896
    leaking intake? high idle white and yellow drips could be oil and coolant. just some thoughts
