airbag light after seat removal
Discussion in 'GMC Truck Forum' started by dannyblake10, Dec 14, 2017.
  1. dannyblake10
    dannyblake10 Full Member
    Mar 14, 2010
    73
    15
    Good afternoon all
    so I have a 2003 sierra slt
    I recently removed the driver and passenger seat to install heated seats. I reinstalled the seats, plugged everything back in, and have the light now
    I did start the truck and drive it out of the garage without the seats so it triggered the light to come on for my srs and "service air bag" across the dash.
    how do I reset this? can I do it with my OBDII reader that I use for engine codes?
    Thanks in advance,
    Danny
  2. MikeG
    2,923
    2,165
    gmtruckclub.com
    Can always try disconnecting the Neg Batt cable for a few minutes
  3. jkeaton
    3,125
    5,213
    Can't use an OBD reader. If the battery disconnect does not work, you need someone (dealer, shop, etc) with an ABS code reader to reset the code.
  4. dannyblake10
    Mar 14, 2010
    73
    15
    yea I tried the battery and no luck
    thanks, I'll see about getting the other code reader
  5. greencamaro1981
    greencamaro1981 Full Member
    Feb 5, 2011
    476
    detention officer
    bozeman mt
    you have to force a relearn, the best way is to remove both batt cables and touch them together (obviously with out anything hooked up to the battery) this will force all capacitors to deplete and reset to factory specs. if the light is on after its a memory fault and has to be cleared by a otc or dealer scanner.
  6. MikeG
    2,923
    2,165
    gmtruckclub.com
    Never knew about touching the cables. Nice trick! :bow:
