ABS light but no codes*fixed*
Discussion in 'Dodge Truck Forum' started by Moostang, Jun 30, 2008.
Tags:
  1. Moostang
    Moostang Senior Member
    Apr 24, 2005
    1,832
    Computer Nerd
    Cali-4 Nye-Aye?
    What would cause the ABS light to come on and not turn off, but the truck is not throwing any codes. The brake light is also on, yet seems to be no braking problems.
    99 Dodge Ram 2500 Turbo Diesel.
  2. junior3382
    junior3382 Senior Member
    3,171
    89
    #2 junior3382, Jun 30, 2008
    The ABS sensor box is located in the cab, if it got wet for any reason it sould signal the lights, however, since this is not a mechanical problem that influencies the operation of the engine and the transmission, the ECU will generally not read it as a problem. However, that is also why there is a seperate light for it. Could also be a fuse as well. Did you check the fuses? There is also a sensor on the brake pedal, and the E-brake lever that should be checked.
  3. mudseeker
    585
    what type of scanner did you use when trying to retrieve codes? most generic code readers will not access the ABS system, such as the ones autozone uses for their free service.
    if the light is on i can almost guarantee their is a code present.
  4. leolkfrm
    7,919
    a good scanner will probably tell you a wheel sensor is not reading and which one it is. I've always said a GOOD scanner is worth their weight.
    ikos10 likes this.
  5. Moostang
    Apr 24, 2005
    1,832
    Computer Nerd
    Cali-4 Nye-Aye?
    I am at work and don't have the scanner right now, but looking at pics, it I think it is the Actron CP9135 are getting tired of trying to figure out the beeps on my old OBD-I Equus for my ford, when needed an OBD-II for the Saturn I got one with a digital display.
    Not sure if he has checked fuses yet (hubby's truck) but I will see.
  6. mudseeker
    585
    i'm sorry, but that code reader will not be able to retrieve ABS codes. it is only capable of retrieveing SES light codes
  7. Moostang
    Apr 24, 2005
    1,832
    Computer Nerd
    Cali-4 Nye-Aye?
    Ugh, well that sucks I suppose there is no other way to see if there are codes without buying a new scanner or taking it somewhere then?
  8. Moostang
    Apr 24, 2005
    1,832
    Computer Nerd
    Cali-4 Nye-Aye?
    I just got an email, he has lost the speedo under 25mph, so he is thinking sensor is dead
  9. mudseeker
    585
    that's a good possibility.
    there's an ABS thread on here where me and crab found some good deals on ABS scanners. work computer won't let me use the search function, but i think i found one for under $200.
  10. mudseeker
    585
    i found it in this section. named "ABS light constantly on" i think. stupid work computer won't let me copy/paste the link.:mad:
    Moostang likes this.
