A/C Freon
Discussion in 'GMC Truck Forum' started by gmctrucks, Nov 1, 2017.
  1. MikeG
    2,923
    2,165
    gmtruckclub.com
    @gmctrucks , I won't be any help here. I had a shop look at my A/C system and was told I had a leak at the valve. On my rig I can't replace the valves; it's a block that bolts to the compressor and a hose assembly. But guess what.......?
    that wasn't the problem. o_O
    7,919
    dont understand it myself....you need a vac which is what i thought i wrote
    nope never needed to change one
  3. gmctrucks
    9,139
    4,880
    #13 gmctrucks, Nov 7, 2017
    A2D6242E-27B1-44FC-B37E-6A0A55084F74.jpeg 24A0237D-C5F0-4611-8312-383AC90A19C7.jpeg Ok guys Advance auto parts had this kit it has different schrader valves so I got it going now I took a picture maybe some member here can use the part number.
    I know for a fact my leak is at the schrader valve I sniffed it out and when taking off the cap it’s under pressure and on the high side my leak detector picked up a leak as well and it has oil around the fill valve so now I just might go down to McAllen to visit my dad and folks for Thanksgiving and use his vacuum pump to be done with it.
    leolkfrm and MikeG like this.
  4. dirtrider73068
    6,924
    4,440
    No the harbor freight does have one that hooks to a air compressor, but have a big comperssor it takes alot of air to pull a deep vacuum, or harbor freight has the vac pumps as well, I bought one and a set of their gauges.
  5. gmctrucks
    9,139
    4,880
    I have never heard a vacuum pump that hooks up to a air compressor my dad always had one that was just a regular vacuum pump and at my old job to where QC had to check the MRE meals under water to see if the bags would leak and be water proof or leak proof in fact I miss that job I was a tech there where I had machines that would seal the plastic bags and we had a box sealer to where twelve meals or bags go in then they would go to a strapped on another machine and put on a wood pallet ready to ship out we even had four huge vacuum pumps that would pull vacuum from some aluminum foil bags that had crackers I’m sure some of you guys that where in the military know about those type of meals example freeze dry strawberries and peaches and so on.
  6. dirtrider73068
    6,924
    4,440
    I never did either till I saw it its alot cheaper and tried it but at the time I had a small 20 gallon compressor it couldn't pull a full vac on my system before it kicked on then never could keep up. It does work and will pull vacuum don't know how. But I can contest it needs alot of air and a big compressor to run it maybe a 60 gallon adn compressor with a high recovery rate. But I would look at the eletric vac pumps to me they are better and meant for pulling vacuum.
  7. scavanger
    scavanger Full Member
    May 15, 2007
    1,779
    1,340
    I got ahold of an old fridge compressor. Crimped off and soldered shut the low side line and rigged it up with a line tap , hook my gauges to it and I got a vacuum plump. Oh, you do need a cord on it.
  8. dirtrider73068
    6,924
    4,440
    Air Vacuum Pump with R134A and R12 Connectors air power vac pump
    2.5 CFM Vacuum Pump kinda like the one I have I may have the 3cfm one its red and not black these are the newer models, but has worked great the few times I used it. The oil that is in it needs to be changed every so often the oil traps the moisture and takes a speacail vacuum pump oil, think auto stores carry it.
  9. gmctrucks
    9,139
    4,880
    With my dad being 91 he had one like that I remember seeing it as a kid.
  10. leolkfrm
    7,919
    the air one is a venturi system...air passe over a hole and creates a vac on the line, it will hold the gauge at a neg point
    hatzie and gmctrucks like this.
