98 mazda b2500 clutch problem?
Discussion in 'Mazda Truck Forum' started by zeoknight, Aug 9, 2015.
  1. zeoknight
    zeoknight New Member
    Aug 9, 2015
    Just replaced the clutch/ slave cylinder and clutch pedal interlock sensor about a month and a half ago, just yesterday morning it was driving just fine until i heard a pop. The clutch pedal was hard where you couldn't push it at all and couldn't push the break, i had to force it out of gear to stop it about ten minites messing with the pedal the line to the slave cylinder popped out and the pedal is completely loose . It takes awhile for the truck to start if you have the pedal all the way down, ive tried bleeding it out but theres absolutely no pressure gain on the pedal it just flops there. Could this be a result of a defective slave cylinder?
    7,916
    or something else broke
  3. zeoknight
    Aug 9, 2015
    We just changed the slave cylinder and its still the same. Theres absolutely no clutch pressure. Would there be any relays for this or would something else cause it?
  4. Kennyray
    Kennyray Moderator
    Oct 6, 2005
    2,028
    2,374
    Fort Wayne, IN
    Can you see if the slave is functioning? Could be the master or something broke inside the bellhousing.
    What do you mean..and could not even push the brake? Did you replace pressure plate.. and..throw out bearing?
    Will it shift when truck is off?
