96 f 150 died..
Discussion in 'Ford Truck Forum' started by tpar1220, Apr 17, 2017.
  1. tpar1220
    tpar1220 Full Member
    Nov 25, 2010
    173
    90
    friend of mine has a 96 f 150 with 300 6 cylinder. said it just died on him other day. was running perfect then just quit. didn't spit or sput or act like ran out of fuel. acted like turned key off. he said he checked for spark and has none. replaced coil and no better. i gave him my code reader to check codes, if any. i told him to pull dist cap and verify shaft is spinning while cranking.
    any other ideas?
  2. gmctrucks
    9,057
    4,797
    Have the ignition module check.
    Good luck! GMC
  3. kbrown11
    kbrown11 Full Member
    Dec 5, 2015
    1,223
    2,145
    Alburquerque
    Check the engine grounds to make sure none are loose from vibration.
    When he turns the key, is there power to the instrument cluster gauges?
  4. tpar1220
    Nov 25, 2010
    173
    90
    he said everything seems normal aside from not having spark. i did tell him to swap the ignition module. apparently there is an abandoned donor truck nearby that has same motor so he swiped coil to try that. when that didn't work he ohmed both coils and both were in spec, so problem not coils. i couldn't remember if ignition module was in distributor or not, but my guess is a bad ignition module.
    thanks for replies
  5. dirtrider73068
    6,882
    4,393
    My 94 chevy ignition module quit and did just what you said, like you reached up and shut the key off.
  6. tpar1220
    Nov 25, 2010
    173
    90
    i am thinking we have it narrowed down to one of two things. ign module or a sensor under distributor. i am not sure if it a camshaft or crankshaft position sensor.
  7. tpar1220
    Nov 25, 2010
    173
    90
    it was the sensor. running perfect once again!
    gmctrucks and leolkfrm like this.
