'92 Chevy Silverado 5.7 liter 350 shudders when hot & loses power
Discussion in 'Chevy Truck Forum' started by chriswooo, Jul 21, 2015.
  1. chriswooo
    chriswooo Full Member
    Jul 21, 2015
    110
    Eastern United States
    #1 chriswooo, Jul 21, 2015
    first-time poster, here... with apologies in advance for anything stupid or ignorant that i might ask or say...
    here's what i've got, what i've done and what i've tried:
    1992 Chevy Silverado
    5.7-liter, 350 tbi
    Acquired vehicle in May, 2015
    170,000 on odometer (suspect actual mileage is higher from looks of engine wear...)
    Conditions:
    Starts and runs great when cold.
    Runs rough (from day one) when at operating temperature or hot.
    Won't cruise smoothly at any speed (when not accelerating or decelerating, the engine hiccups, shudders, misses).
    Gas mileage is very poor. (I understand this vehicle has low MPG in any condition.)
    Dies at stop when hot.
    Misses (on one cylinder, it sounds like) when hot, at idle, in gear, with A/C on.
    Idles better when hot if taken out of gear OR turning off A/C.
    The Power under load when it's hot is very weak; sputters, shudders and even dies, occasionally.
    Use:
    Began using vehicle for work tasks, pulling loaded 16' dovetail trailer, in mid-June, 2015.
    Runs well at beginning of day; 20 miles down the road starts to shudder and miss; at the end of the day it's limping in and I'm wondering if i'll make it home.
    Research, Diagnostics and Repair history:
    Began diagnosing and making minor repairs July 1.
    Took it to a shop who said I had a vacuum leak and adjusted the timing.
    Lost confidence in shop when truck demonstrated same behavior.
    Suspected fuel/fire problems.
    Replaced fuel filter.
    Replaced fuel pump relay.
    Replaced spark plugs.
    Checked wires.
    Talked to some smart people; consulted with a 45-year large equipment mechanic; read more stuff online; watched some videos on youtube.
    Replaced distributor cap.
    Replaced distributor rotor.
    Adjusted timing.
    Minor improvements noticed; same problems evident when hot.
    Suspected fuel regulation problems.
    Inspected injectors for spray pattern; shows even spray with adequate pressure (visually, anyway).
    Replaced MAP sensor.
    Replaced Idle Air control Valve (IAC).
    After replacing the IAC, the idle speed jumped 1000 rpms.
    Adjusted timing.
    Replaced temp control sensor (the one that talks to the EMC).
    Checked timing.
    Replaced EGR valve.
    Replaced EGR vacuum solenoid.
    Adjusted timing again (this one done by a racing mechanic who knows what he's doing).
    Tested for vacuum leaks (spray).
    Replaced ignition coil.
    No change in performance.
    Took it to a second repair shop, recommended by one of the racing machanics, who suggested a clogged catalytic converter due to whiteness on the manifolds and/or a sticky thermostat.
    Replaced Thermostat. Vehicle was running at about 185 degrees before and is running about 185 degrees with new one.
    Took it to a muffler shop and had the catalytic converter tested and it's doing its job (though i do have some pipe cracks between the converter and the muffler).
    Today I tested compression with these results: 1-150, 3=145, 5=150, 7=160; 2=160, 4=130, 6=150, 8=100.
    While checking compression, all 8 spark plugs show chocolate-colored markings, indicating no lean/rich conditions.
    She's running _pretty good_ now, after all of this... but i still have the ORIGINAL problem/complaint: when hot under load, she misses, shudders, quakes and loses power. this must be harming my fuel mileage and makes her unreliable - the latter condition unacceptable for work use.
    I have NOT tested fuel pressure (tho it appears to be spraying healthy amounts from injectors), or throttle position sensor (can't see that it applies) or fuel pressure regulator.
    So, my question is: WTF? Ignition control module? Distributor? Intake manifold gasket? head gasket? i mean, sheesh...
    I appreciate your time in reviewing this information.
    Thanks for any guidance.
  2. mando1
    mando1 Full Member
    Dec 15, 2012
    122
    89
    I have a 94 Silverado that was doing the same thing as yours.After replacing some parts and still having the same problem,I than went ahead and replaced the ignition control module and that took care of the problem.This happened about 3 years ago.A year after that,my truck would be going down the road and than it would just quit.That time.it was the distributer that was causing the problem.At that age,unless most parts have been replaced,they will be about ready to go out.Right now I am having a problem with the Emission/Exhaust System but am waiting for a part that I need to hook up my computer to check the error codes and history of the engine.
    Mando
    5 people like this.
  3. Bad88
    Bad88 Full Member
    Dec 8, 2014
    2,085
    4,045
    New York
    You've got imbalanced compression in my opinion. Did you check compression hot & cold? Got any oil in the water or water in the oil?
    3 people like this.
  4. chriswooo
    Jul 21, 2015
    110
    Oil looks fine...
    Water may be contaminated. Need to have it tested this week.
    Compression check was cold only. I will test it hot tomorrow.
    What's a solution for imbalanced compression?
    Thanks for inputs...
  5. chriswooo
    Jul 21, 2015
    110
    Thanks, Mando... I'll pull that ignition control module and take it in for a test...
  6. skippy2235
    skippy2235 Senior Member
    Nov 24, 2010
    59
    Are you using ac delco plugs. Mine was like that until he change.
    get rid of BOSH.
    4 people like this.
  7. mowfixer
    mowfixer Full Member
    Jun 20, 2011
    765
    1,462
    Sanford, NC
    Those ignition modules have thermal compound between them and the mounting plate. That compound can dry out and become ineffective causing the module to overheat, causing problems only when vehicle is hot.
    When you put module back on,use some alcohol and clean all the old thermal compound off the mounting plate and ignition module if it tests good and your re-using it. Put only a small layer of compound back on. More is not better.
  8. chriswooo
    Jul 21, 2015
    110
    Thanks, mowfixer... question on that compound... what's it called? I've read that these solutions can be dicey if inferior products are used. What properties should I look for in this specific application?
  9. chriswooo
    Jul 21, 2015
    110
    Autolite. 25.
  10. MrMarty51
    Best stuff, Permatex 22058 Dielectric tune up grease, can be used for many things, sparkplug wire boots, etc.
    5 people like this.
