5.3 tourque specs
Discussion in 'Chevy Truck Forum' started by heavychevy85, Mar 2, 2011.
  1. heavychevy85
    heavychevy85 Senior Member
    May 30, 2008
    317
    lawn care and landscaping
    Muncy, PA
    going to be installing my new head gaskets on my 5.3 need tq specs on the heads and the intake any help would be appreciated thank you all
    That would be 100 ft. pounds on heads and 40 on the intake.
    Get you all torque specs need be.
  3. mudseeker
    585
    those head bolts are a torque to yeild and a torque angle gauge is needed to do it right.
  4. mudseeker
    585
    1. cylinder head.gif Tighten the M11 cylinder head bolts a first pass in sequence to 30 Nm (22 ft. lbs.).
    2. Tighten the M11 cylinder head bolts a second pass in sequence to 90 degrees using the J36660-A.
    3. Tighten the M11 cylinder head bolts (1,2,3,4,5,6,7,8) to 90 degrees and the M11 cylinder head bolts (9 and 10) to 50 degrees a final pass in sequence to using the J36660-A.
    4. Tighten the M8 cylinder head bolts (11,12,13,14,15) to 30 Nm (22 ft. lbs.) . Begin with the center bolt (11) and alternating side-to-side, work outward tightening all of the bolts
    intake is 44 INCH pounds on first pass and 89 INCH pounds on final pass. intake.gif
  5. heavychevy85
    May 30, 2008
    317
    Muncy, PA
    i just baught a chiltens manuel so i belive im good to go thanks every one for the info
