2007 GMC 2500, passenger side air won't work
Discussion in 'GMC Truck Forum' started by Robert78.5, Jul 23, 2017.
  1. Robert78.5
    Robert78.5 Full Member
    Sep 10, 2006
    101
    Sales manager
    Manitoba
    A friend had his truck into shop and they changed a solenoid for heater controls?? Still does not work properly. Cold on driver side but passenger side throws hot air. Anyone experience this? This is while running the air conditioning. .
  2. kbrown11
    kbrown11 Full Member
    Dec 5, 2015
    1,068
    1,885
    Alburquerque
    #2 kbrown11, Jul 24, 2017
    Probably a blend door actuator. Sometimes the grease they put in the actuator shorts out the connection, so all you have to do is take it out, take it apart and clean all the grease out of it. Put it back together with new grease. I have seen resistors go out inside the actuator so it is possible that the actuator will need to be replaced if it's not the grease problem.
  3. dirtrider73068
    6,531
    3,913
    My 03 bonneville did this and what I researched was it was low on freon, I added a can and all vents blow cold air. Might have the freon checked it could be low but also a blend door not working right.
  4. leolkfrm
    12,547
    7,607
    sure it works...roll down the window!
  5. gmctrucks
    8,444
    4,054
    My brother is having problems with his 2004 HD truck right now the same thing is happening from what he looked up it can be a royal pain in the butt taking off the dash to get to the doors Google also has a lot of info on the problem and so does You Tube he had some dash controller changed taking a chance it might fix it but no it didn't work just a heads up.
