2000 GMC Yukon Service 4WD Light
Discussion in 'GMC Truck Forum' started by SQBADOG, Oct 21, 2010.
  1. SQBADOG
    SQBADOG Full Member
    Jun 1, 2010
    302
    115
    City of Brotherly Hoods.
    #1 SQBADOG, Oct 21, 2010
    I have a 2000 Yukon XL with 153k. It has the 5.3 Vortec. Great running truck.
    On the way home last night, the 'Service 4WD' light came on.
    I checked the manual, it said that there could be a problem...nice.
    Did a search of the forum, did not see anything posted.
    Truck is a family mobile, not used hard, highway miles.
    Changed rear diff fluid 10k ago because the pan had started to rust thorough and was wet.:confused:
  2. 87c10slammer
    87c10slammer Senior Member
    Mar 20, 2008
    3,221
    49
    levittown pa
    its probley your transfer case oil. your suppose to service it every 100k and they make trucks so smart that it knows when the oil is breaking down.
  3. cannedham1
    cannedham1 Full Member
    Jun 29, 2009
    17
    4wd light
    I had the same problem last year . It was the wire harness under the hood. The dealer said water had got into it and corroded the connection.
  4. SQBADOG
    SQBADOG Full Member
    Jun 1, 2010
    302
    115
    I actually did that service.
    Wonder if it generates a code.
    Read that the transfer switch is really common. Hmmmmm
  5. 99-GMCSierraZ71
    99-GMCSierraZ71 Full Member
    Oct 20, 2009
    Nanaimo BC Canada
    I had that light come on, I ended up having to replace the switch cause everything was working OK
    I'm not sure what you call it but its the electronic switch on the dash you push when you want to change it from 2 wheel drive to 4 wheel
    Cost me 50 bucks...fixed
  6. SQBADOG
    SQBADOG Full Member
    Jun 1, 2010
    302
    115
    It was the switch. Technical bulletin issued.
  7. crabtruck
    141
    Thanks for the update, glad to hear it's fixed.
    Had looked before and missed this TSB
    Did you ever have codes read, get a B2725 ?
