1998 Dodge 2500 Transmission Problems
Discussion in 'Dodge Truck Forum' started by Michael Dunn, May 15, 2017.
  1. Michael Dunn
    Michael Dunn New Member
    May 15, 2017
    Hi I have a 1998 Dodge 2500 with the 5.9L cummins.
    I am having issues with my transmission and hope somebody can tell me what the problem is. Here are all the issues.
    1.When I first start the truck and go into drive it doesn't start going right away then it eventually kicks in with a thump. After that it accelerates right away but many times it thumps.
    2.The transmission shakes while accelerating seems to mostly happen between 2nd and 3rd gear.
    3. When I am at a stop the car will suddenly try to lunge forward with the break applied.
    4. The car sometimes slips in and out of overdrive.
    5. There seems to be a real lack of power when I am accelerating.
    6. Shifting between gears is often rough.
    Not sure what all this breaks down to but any help would be appreciated. There is no check engine light on.
    Thanks.
  2. gmctrucks
    8,576
    4,169
    Run for codes with a scanner
