1997 GMC Sierra K1500 no fire
Discussion in 'GMC Truck Forum' started by janicki84, Dec 29, 2017.
  1. janicki84
    janicki84 Member
    Dec 29, 2017
    I don't have any fancy tools to test things with, so I use what I have. just getting ill with this truck and really want it to run.
    6,924
    4,440
    What is ckp? You can go to harbor freight and buy a cheap multi meter for around 5 bucks that will do the trick, and pick up a haynes repair book autozone has them it has step by step repairs and even tells you how to test sensors but need a mutli meter to read voltage and resistance. Test light is good to have but just shows there is voltage in a circut its good to have as well.
  3. kbrown11
    kbrown11 Full Member
    Dec 5, 2015
    1,233
    2,158
    Alburquerque
    If I recall you can have the ICM tested at the auto parts store.
  4. janicki84
    janicki84 Member
    Dec 29, 2017
    i borrowed a multi meter. coil was good. I also changed the ckp(crank positioning sensor) still no spark. i am lost. if it is the ECM, i will have to do something else because used they are around $300.
