1993 Sierra 1500 heater blower works sometimes
Discussion in 'GMC Truck Forum' started by donpg101, Dec 6, 2016.
  1. donpg101
    donpg101 Member
    May 31, 2011
    Recently my heater blower stopped working most of the time. It will occasionally turn on after driving for a while. When the heater is set to off and I push a setting I hear a thump coming from the passenger side floor, but no blowing. When I changed fan speeds I hear a clicking coming from the glove box. The truck is producing heat but not blowing from the vents. So far I have only changed the resistor, it looked like mice were using it as a toilet. Before I tear apart my dash I would appreciate a little guidance. This is my first time dealing with this type of issue. Thanks.
  2. scavanger
    scavanger Full Member
    May 15, 2007
    1,779
    1,340
    Couple of things here . could be the resistor,but usually that is just speed specific . The other thing is ,behind the glove box are some connections and a relay. the main power connection can get bad. Can heat up big time maybe cause an electrical fire. I would check that sooner rather than later.
    Oh can also be the fan switch but that is usually speed specific also.Gives you warning by not working on some speeds
    gmctrucks and donpg101 like this.
  3. poncho62
    poncho62 Full Member
    Aug 17, 2013
    816
    1,305
    semi retired
    Hanover, Ont, Canada
    Probably have a loose wire under the dash which is making contact every now and then. Gonna have to get under there and wiggle the harness around and see whats happening. Pull the glovebox out, the wiring for the blower etc is right there
  4. donpg101
    donpg101 Member
    May 31, 2011
    I was able to get it to turn on by banging on what I assume is the blower motor. It worked for the duration of my drive but it did not stay on for my next trip. Do I need a new blower motor or might this just be a connection at the motor?
  5. leolkfrm
    7,916
    check the resistor and plug for burn marks, put 12v direct to the motor, both should answer your question
    donpg101 and gmctrucks like this.
  6. dirtrider73068
    6,923
    4,437
    Most times if you tap the blower motor and it comes on then it its going bad or is bad and needs relaced, I had to change mine for this reason would work then not work hit it with your foot would come on, put a new one in works great.
  7. kbrown11
    kbrown11 Full Member
    Dec 5, 2015
    1,232
    2,158
    Alburquerque
    Any luck? I would say disconnect the motor and using a multimeter check the plug that connects to the motor to see if you are getting power at the motor.
  8. MikeG
    2,919
    2,163
    Richland, Wa
    #8 MikeG, Dec 14, 2016
    Relay & Resistor, On the resistor itself there is a coil pack for the LOW(er) speeds and a seperate coil for the HI. If one goes out you will lose the associated speed, resulting in no blower function. If one is replaced you should replace both as well as the plug connector to the Resistor. I had the same problem in my 96 K1500.
  9. MikeG
    2,919
    2,163
    Richland, Wa
  10. dirtrider73068
    6,923
    4,437
    I lost low speed on mine I just replaced the resistor, my connector and stuff looked fine. What happend to a just a speed switch whats the need for all this resistors and junk.
    donpg101, MikeG and gmctrucks like this.
