1991 4.3 will I hear the fuel pump engage?
Discussion in 'Chevy Truck Forum' started by Smokin1991, Dec 28, 2014.
  1. Smokin1991
    Smokin1991 Senior Member
    Sep 20, 2012
    174
    104
    Northern Illinois
    Sure enough....I replace the master cylinder reserve, exhaust system, bearings, and now the truck won't start.
    At first I thought it was the damp, rainy days we had, as it turns over and cranks but will not fire. But two years ago I replaced the cap and rotor and that solved the damp issue.
    So today I get some starting fluid, spray into carb. Fires right up then stalls!
    Here comes my next question...when i turn the key to accessory, should I hear the fuel pump prime? All I hear is a small clunk, sounding like it is coming from under the hood. I hear it on my 1999 4.3 Astro.
    Things replaced over the last two years:
    coolant sensor
    oil pressure sensor
    cap-rotor-plugs-wires
    Thanks!
  2. cjpayne
    cjpayne Senior Member
    Aug 4, 2013
    367
    481
    Electrical/mechanical assembler(peon)
    Inola, OK
    Have a friend turn the switch to "on", not "accessory", while your under the tank. You should hear it prime.
  3. Smokin1991
    Sep 20, 2012
    174
    104
    Northern Illinois
    I am sorry, I mean "on" right before cranking.
  4. MrMarty51
    Some of them pumps is mighty quiet, I have had to use a large screwing driver, stick the handle to My ear, the blade to the tank, then, have someone turn the key to the "RUN" only position, not the cranking position.
    Pump should run for about 3 to 5 seconds.
    If You are hearing a clunk noise from under the hood, the fuel pump relay is towards the R.H. side, bolted to the fire~wall, hold onto it, have someone turn the key to the run position, see if it klunks or klanks whan the key is turned.
    Disconnect tank harness, might be just forwards of the tank, see of klunk still persists. If not, and, You did`nt hear the feul pump run for the few seconds, then, remove the box, clean off top of tank and replace the pump and strainer sock.
  5. cjpayne
    Aug 4, 2013
    367
    481
    Inola, OK
    I've never tried it but, you may be able to feel the pump vibration on the tank.
  6. Smokin1991
    Sep 20, 2012
    174
    104
    Northern Illinois
    If it does clunk, what then? That does seem like where the sound is coming from.
    Try this to test the pump ..run 12 volts to G terminal at adld scan port ...see if pump comes on ..just for a few seconds..if pump stuck might burn wires .
    You should here pump run ..for a few seconds with key on. The relay should click..when key turn on. Also check ecm fuse.
    click here
  8. Smokin1991
    Sep 20, 2012
    174
    104
    Northern Illinois
    Fuse okay....truck is a shop in parking lot. Getting colder.....
  9. chevychase
    Do as advised by all brrr..the quick check at relay..or G at scan port will tell you if pump is good...unless a wire is broke..or lost ground at tank to frame..these rust bad...no ground no go.
  10. chevychase
    Can try this..if pump just quit..get a something like a board..tire tool thump on bottom of tank..while someone turns key on.
    Might get it to start this way..get it home to change..i have done this.
