1990 extra cab air conditioner wont turn on
Discussion in 'Nissan Truck Forum' started by gogi, Jul 14, 2016.
  1. gogi
    gogi New Member
    Jul 14, 2016
    air condition worked but made screeching noise from alternator,stepping on brake put dash lights on with truck off. mechanic found cause was short in tail light. fixed and no mor dash brake light problem tried air conditioner now and wont go on.i'm thinking relay? anything else I should consider.thanks RIP
    MrMarty51 likes this.
    6,919
    4,431
    Fuses make sure it didn't short or blow a fuse. I found my amp in my truck not turning on amd when it did would come a couple seconds then shut off. Found the big 30 amp fuse was shorted and melted on one side. Could be what happened to yours.
  3. gmctrucks
    9,131
    4,873
    GREMLINS for sure and I agree 100% with DR check your fuses.
    Good luck! GMC
  4. leolkfrm
    12,762
    7,911
    may be a compressor....is the clutch engaging?...screeching is an indication of belt slippage,
    gmctrucks and MrMarty51 like this.
  5. gogi
    gogi New Member
    Jul 14, 2016
    nothing happens no click no noise no nothing
  6. gogi
    gogi New Member
    Jul 14, 2016
    some one said
    the cigarette lighter fuse was also the air conditioner fuse? if not which is it? I don't have a fuse labeled ac furse in box
  7. leolkfrm
    12,762
    7,911
    did you look at the compressor after turning it on? ac has its own fuse, was it working before?, might be low on freon
  8. MrMarty51
    With the ign. switch turned to run, check for voltage at the A/Cs pressure switches.
    The switch located at the filter/dryer{silver looking can} is a clutch cycling switch.
    No voltage there then recheck the fuses and or the wiring.
    If there is power to one side of that switch but not the other then get a set of gauges and check the A/Cs pressures.
    Must be a charged system for the cycling switch to turn on.
    If there is voltage at the cycling switch then check to see if there is voltage getting to the A/Cs clutch wire. At the clutch, green and black wires, voltage should be there if the system is charged.
    If there is no voltage at the cycling switch then check the fuses.
    Welcome to the forum Gogi
    gmctrucks and leolkfrm like this.
