1990 Chevy Pickup 4x4 Indicator Light
Discussion in 'Chevy Truck Forum' started by wsmm, Dec 19, 2017.
  1. wsmm
    wsmm Member
    Jul 9, 2012
    17
    Mid-Michigan
    The 4x4 indicator light on my 1990 Chevy K1500 (WT) is not working. While it was up on the hoist today we tested the 4x4 and it is working. If the light is burned out what do I need to do to replace it? What else should I check?
    Thanks,
    Bill
  2. MikeG
    2,803
    2,070
    Richland, Wa
    I couldn't find anything on the Inter-webs, maybe check a Chilton's ?
  3. greencamaro1981
    greencamaro1981 Full Member
    Feb 5, 2011
    475
    111
    detention officer
    bozeman mt
    should be little 1/4 turn bulb sockets, usually a 194 bulb is used
  4. leolkfrm
    12,741
    7,894
    the light for the floor shifter? check for corrosion on the wires
  5. jkeaton
    3,115
    5,197
    Usually a couple of screws holding the plastic cover on. Take those out, list up the cover, twist the old bulb out, install new bulb. Should be readily apparent by looking at it.
