1990 4 cyl 4x4 tail lights brake lights turn lights haszard lights all out
Discussion in 'Nissan Truck Forum' started by willyc66, Jun 21, 2015.
  1. willyc66
    willyc66 New Member
    Jun 21, 2015
    I have an 1990 4x4 hard body most of the lights are out cant find a bad fuse any were need all the help I can get
  2. Kennyray
    Kennyray Moderator
    Oct 6, 2005
    2,022
    2,370
    Fort Wayne, IN
    First thing to do is check the grounds.
  3. MrMarty51
    YUP, Check all the grounds at the back end of the truck.
    There is, or, should be a harness plug that can be undone, check the pins in the connectors, be sure that there is no corrosion inside of these.
    Be sure that the grounds to the frame at the back end are clean and tight and, there are no broken wires.
    There too, might be grounds to the body, under the tail light assemblies, remove the assemblies and check these.
