1989 3.0 V6 Smoking like crazy
Discussion in 'Toyota Truck Forum' started by 89xCab, Jun 18, 2017.
  1. 89xCab
    89xCab New Member
    Jun 18, 2017
    I have a 1989 pickup, it is a manual, 4x4, and has the 3.0L. I just got it 2 weeks ago for a weekend warrior type truck. It smoke a bit when you would start it up, but then go away in a couple minutes, now it just billows smoke and does not go away. Seems like it is probably the head gasket, but I wouldn't mind rebuilding the motor since it has a ton of miles on it. Where can I find a good rebuilt motor or someone to rebuild the motor in the Seattle area?
  2. gmctrucks
    9,056
    4,793
    It could be a clogged up PCV valve cheap part or bad valve guide seals view the video below.
  3. jkeaton
    3,112
    5,196
    Hit up google for your area and start reviewing places that rebuild motors.
